WheelHorseEnjoyer 25 #1 Posted June 27, 2022 How universal is the push blade? There is an auction coming up in my area and it has a wheel horse push blade on it. I dont know if it would fit my B100. I was hoping you you kind people on here could tell me about how universal the wheel horse blades are and about how high I should bid it up to. Thank you. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,845 #2 Posted June 27, 2022 Very little difference in these models Dozer DNA of long tractor frame dozer blades 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) 1984-1989 model 06-48BC01 (They are now 48" wide) 1990 model 06-48BC02 (Last blade to have 3 angle positions) 1991-1993 model 06-48BC03 (First blade to have 5 angle positions) 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) Share this post Link to post Share on other sites
ri702bill 10,570 #3 Posted June 27, 2022 (edited) Be sure the auction has ALL the pieces - you will need the clamp-on axle mount if you do not already have one. The wear edge on the later polws is reversable - best scenario is it has a new edge - worst is both are worn down and needs to be replaced. Be sure all the mechanism to angle the plow is there - perhaps download the manual if you know the model number and familiarize yourself with all the pieces. I bought a used in very good condition 79350 48" complete setup about 5 years ago for $200 - wear edge had one good more year left in it... Bill Edited June 27, 2022 by ri702bill Share this post Link to post Share on other sites
Ed Kennell 43,783 #4 Posted June 27, 2022 to the There are two different length plow frames. The blades themselves are the same. The plow frame attaches to the rear axle and requires the rear axle bracket. I believe the B-100 is a short frame tractor and would require a short plow frame. Plow frames with blade sell for around $150 in my area. The axle bracket sells for $40. Share this post Link to post Share on other sites
SylvanLakeWH 29,814 #5 Posted June 27, 2022 And In Michigan the frame and blade go for about $125-150… If linkages (cable release and adjustment rod) aren’t all there then I’d go a bit less as you would need to fabricate/ add those. Share this post Link to post Share on other sites
cafoose 3,520 #7 Posted June 27, 2022 (edited) If it's a V frame like this it's too short. Frame like this should work. Make sure it's similar to this one and not for a vertical engine tractor: Edited June 27, 2022 by cafoose 2 1 Share this post Link to post Share on other sites
WheelHorseEnjoyer 25 #8 Posted July 4, 2022 @cafoose Thank you that helped me figure out what it was. 1 Share this post Link to post Share on other sites
WheelHorseEnjoyer 25 #9 Posted July 4, 2022 @cafoose @roadapples @SylvanLakeWH @gwest_ca @ri702bill @Ed Kennell Thank you to all that responded to my original decision! This blade was at the auction yesterday and here is what I came home with. I did come home with the blade but when I was looking at it it was missing the piece that went onto the tractor to make it go up and down. So I figured I would have to fabricate one. But then there was also a C-120 there which I said ah what the heck one more couldn't hurt and so I bought that for $90. (I got the blade for $40) When I got it all unloaded and started to work on the C-120 I crawled under it and there the lift deal that went on the was. It was already mounted onto the C-120! How lucky was that? Again thank you to all that responded and pointed me in the right direction. 2 2 Share this post Link to post Share on other sites
oliver2-44 11,062 #10 Posted July 4, 2022 You got aa good deal! Share this post Link to post Share on other sites
