BMW1
3 point lift assembly bearings for D series
BMW1
I bought a 3 point hitch from someone on Face book but the 3 point hitch lift assembly bearings were not included.
The are NLA.
Does any know a supplier for these or have two they are willing to sell?
I looked at McMaster and could not find one with the sizes needed.
The part# is 8340 in the 3 point hitch diagram below.
Thank You.
pfrederi
They are not bearings just steel brackets with 1 big and two small holes.  Try A to Z tractors (Vendors section here)
pacer
Yeah, that little guy is gonna be SCARCE and your best bet is to contact one the vendors here on the forum (like @pfrederi mentioned)
Reckon the seller just forgot them, did you try and re-connect with him? they surely arent anything a person would need except for the 3 point....
BMW1
I did lookup the part on A-Z tractor and saw it listed as 8340-u Block.
I sent an email to A-Z and included images above.  They indicated that was the part I needed:greetings-clappingyellow:  The -u means used.  Not sure why the description indicates Block though.  I am hoping it works.
Problem with reconnecting with seller is I bought this quite a while ago, opened the box when it arrived and looked like everything was there but did not go through it all, so that's on me.  Now, over a year and a half  later, I am finally getting around to putting it on and noticed those blocks/bushings/bearings were not included.  The sway chains, yokes, clevises, and sway chain attachment brackets were also missing.  A-Z has the brackets and blocks/bushings/bearings but the other items are out of stock but I can get those pieces at a farm and hardware store.  The person also forgot to mention one of the lower link arms was broken at one time and welded where the adjustment assembly attaches and the other arm had a bend in it.  The lower link arms were at the bottom of the box.  I opened the box and saw two arms but did not inspect everything.  Again, that's on me. definitely will inspect things closer next time.  Weld looks good but needed some clean up and I was able to straighten the bend in the other arm.
Thanks for the assistance.
Jeff-C175
I believe as Paul mentioned earlier, it's not a bearing... just a block with some holes drilled in it.
gt14rider
Playing around with bushings for GT 14. Going to do both sets of blocks.
Lee1977
Wouldn't be hard to make the hardest part is the outside shape and that could be square and work just as well.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
