RED-Z06
Anyone chiseled out balance gears?
Jeff-C175
47 minutes ago, RED-Z06 said:
Think an air chisel might give more control?
Dunno!  You wanna give it a try and let us know?  I don't have one or I would have tried it!
RED-Z06
They are handy...just got one myself as a last resort to get the steering wheel roll pin out of a simplicity...an hour of hammering and it got it out in 10 seconds
  • Like 3
kpinnc
Jeff,
Did you replace the valve springs? I think worn out springs regulary make clacking noises in a Kohler, even with the lash set correctly.
If you set the valves too tight and the noise goes away, that's the surefire sign the springs are worn.
Edited by kpinnc
Jeff-C175
22 minutes ago, kpinnc said:
Jeff,
No, the only thing I did was pull the pan and remove the BGs.
If I ever have it out again it will be for a full rebuild and I'll definitely keep this in mind, thanks!
ebinmaine
@RED-Z06
Did you pull the gears yet?
ebinmaine
On 9/4/2022 at 12:13 PM, Jeff-C175 said:
crank gear at the red arrow
Jeff these pics aren't showing anymore. Do you still have them to re-post?
I'm looking to do the BG removal on a K341.
RED-Z06
6 hours ago, ebinmaine said:
@RED-Z06
I did not...shes still hammering hard as ever, going to have to do it soon, i pulled that engine so many times in 2022 i didn't want to do it again...
ebinmaine
New year, new pull count?
I did a set this morning.
ebinmaine
I used a method mentioned by @kpinnc based on a thread by ((??)). @Marv...
Drive the pins out.
