CodyP
trans won't go into high selection
CodyP
low is just fine but high won't engage and when it does it just slides out
squonk
You probably have a broken /bent shifter fork. They are real flimsy. Trans has to be torn down. :(
  • Thanks 1
CodyP
hey is the part number 3503 fork shift right? just need to know so I can locate one
ri702bill
@CodyP - as I have said before - The OE replacement parts are only as good as the parts they replace. Search for the Hi-Lo fork upgrade done by adding to the welded area. Fix it once, fix it for good...
Bill
  • Thanks 1
