RandyLittrell 3,894 #1 Posted June 19, 2022 I have a K-321 magnum engine that was a standalone engine with key on the motor. I am thinking about putting it in my 1277 but want it to look like a K series. Not sure if I would fit right with the magnum sheetmetal as well. Thanks!! Randy Share this post Link to post Share on other sites
roadapples 6,983 #2 Posted June 19, 2022 I have an off the shelf 1994 magnum 16hp in a 1974 C160. The left side of the hood did rub the tin slightly. I just pulled the hood out with my fingers a bit. Can't tell I did anything 3 Share this post Link to post Share on other sites
kpinnc 13,780 #3 Posted June 19, 2022 The flywheel beating plate is the big difference between K and Mag single cylinders. The starter on Magnums bolts to the bearing plate, where the K series bolt to the block. You're better off swapping the bearing plate (don't forget the crankshaft endplay setting) and treat it as a shortblock. Almost a complete teardown. 3 Share this post Link to post Share on other sites
Bill D 2,097 #4 Posted June 19, 2022 1 hour ago, kpinnc said: The flywheel beating plate is the big difference between K and Mag single cylinders. The starter on Magnums bolts to the bearing plate, where the K series bolt to the block. You're better off swapping the bearing plate (don't forget the crankshaft endplay setting) and treat it as a shortblock. Almost a complete teardown. If you do this, plan to to machine the Magnum block for points. The Magnum bearing plate holds the magneto. Or plan to build some sort of flywheel trigger ignition system and swap to a K series flywheel. Last option would be modifying the engine sheet metal from the K to fit the M. Just put the Magnum on unless you really can't stand the look, much easier. 2 Share this post Link to post Share on other sites
953 nut 57,994 #5 Posted June 19, 2022 8 hours ago, RandyLittrell said: want it to look like a K series. By this do you mean you intend to use the Starter Generator rather than the magnum electrical system? Here is some information from Brian Miller's site about the differances and similarities between K and M engines. Differences Between the Kohler K-series and Magnum Engine Blocks - Unlike the old school small- and big-block Chevy V8's, the Kohler K-series and Magnum engine block models K241, M10, K301, M12, K321, M14, K341 and M16 are not all the same. There are several variations in bolt patterns and PTO end flange configurations between these blocks. Before replacing an engine block and if possible, the best thing to do is have the original engine rebuilt, then all the original accessories will attach to the original block with no modifications. But if the original engine block is not rebuildable and damaged beyond repair, another block of the same type (specification number) will need to be acquired. If interested in purchasing a bare block, please email me several detailed, sharp photos of your original engine block taken at all sides so I match it to one I may have in stock. Packaged shipping weight for each bare block is 45 lbs. The Major Differences Between the K241, M10, K301, M12, K321, M14, K341 and M16 Kohler Engine and Blocks - The K241 and M10 blocks have a STD cylinder bore of 3.250" and the stroke is 2.875". All of these blocks have an exhaust valve diameter of 1.125" and the intake is 1.375". Some rare K241 blocks have "K301" embossed on the PTO end. These have a thicker cylinder wall than ordinary K241 blocks. The K301 and M12 blocks have a STD cylinder bore of 3.375" and the stroke is 3.250". There are no other major differences between these two blocks. These blocks have the same size valves, and most external parts will interchange. Due to the smaller cubic inch displacement, which lessens the amount of air that enters the engine, theses engines use a Carter or Kohler #26, or Walbro #52 (1.07" throttle bore) carburetor. The K321 and M14 blocks have a STD cylinder bore of 3.500' and the stroke is 3.250". There are no other major differences between the K241, M10, K301, M12, K321 or M14 engines. The early K321 blocks have an exhaust valve diameter of 1.125", and the valves in the later K321 blocks are the same diameter, which is 1.375". Some internal, but most external parts on the K241, M10, K301, M12, K321 and M14 engines will interchange, with the exception of the early style K241 cylinder head and size of the carburetor. Due to the larger cubic inch displacement, which increases the amount of air that enters the engine, the K321 and M14 engines use either a larger Carter or Kohler #28 or #30, or Walbro #60 (1.17" or 1.2" throttle bore) carburetor. The K341 and M16 blocks have a STD cylinder bore of 3.750" and the stroke is 3.250". There are no other major differences between the K241, M10, K301, M12, K321, M14, K341 or M16 engines, except the valves are the same diameter, 1.375". And the K341 and M16 blocks have 10 cylinder head bolts. Due to the larger cubic inch displacement, which increases the amount of air that enters the engine, the K341 and M16 engines also use a #30 (1.2" throttle bore) carburetor. And most external parts, except the cylinder head and air shields, will interchange with the K241, M10, K301, M12, K321, M14, K341 and M16 engines. The Major Differences Between the Kohler K-series and Magnum Engine Blocks - Some Kohler blocks have wide base flanges (for the wide, deep oil pan) and some have a narrow base with no flanges. (These are used on Cub Cadet, Ford, certain John Deere and Wheel Horse garden tractors.) Most Magnum blocks are wide base, and very few are narrow base. The very early K241 10hp blocks have no indentation for installing an upper mount gear starter (mounting bolts are below the starter motor). Also, some of these older blocks with flanges have no holes drilled for converting to a narrow base oil pan. (But holes can be drilled and tapped.) Some blocks have either a drilled or threaded oil dipstick tube hole next to the cylinder, above the crankcase, while others have no hole present. Some blocks have provisions for a starter-side oil dipstick tube, and some don't. Some blocks came with counterbalance gears and some didn't. Some have expansion plugs where balance gear stub shafts can be installed, and although certain blocks have the bosses, some have no holes drilled for the stub shafts. All Kohler Magnum blocks have no provisions for ignition points. Some blocks have two threaded holes for installing an exhaust pipe flange, and some don't. Some blocks have provisions to install a mechanical fuel pump, and some don't. Some blocks have different bolt patterns on the PTO end, and Gravely blocks have a raised circular flange. (See below.) Some K241 blocks with K301 embossed on the PTO end have a thicker cylinder wall, and some K241 blocks without the K301 embossing have an ordinary thickness cylinder wall. The 12 fin K341 blocks have an ordinary thickness cylinder wall, and the 13 fin K341 blocks have a thicker cylinder wall. Other than all of the before mentioned È, everything else on the Kohler K-series engine blocks are pretty much the same. The Differences Between the Old Kohler K-series and the Newer Kohler Magnum Engines - The Magnum engines replaced the K-series in later years. The Magnum engines are basically the same engine as the K-series. The main differences are, besides the baffle shields (sheet metal) that covers the block, the Magnum has solid state ignition, a fixed main jet (Walbro) carburetor and the starter fastens to the OEM bearing plate instead of the engine block. And there are no provisions for using ignition points. Most of the external and all the internal parts are interchangeable, and most aftermarket (high performance) parts are interchangeable with either engine. A Kohler K-series and Magnum M10, M12, M14 and M16 single cylinder engines will fit in place of a Kohler K241 or M10 engine. These all basically have the same external dimensions, with the exception of the 16hp, which has a larger cylinder. Kohler engines are like the old school small block or big block Chevrolet V8 engines. A small block 400 CID engine can be used in place of a 265 CID engine, and a big block 572 CID [crate] engine can be used in place of a 366 CID [truck] engine, because they basically have the same external dimensions. The main difference with Kohler engines is the bolt patterns on the PTO end of the block. Each block is made specifically for the garden tractor, small motorized vehicle or lawn and garden equipment it goes in. When replacing an engine block with another, make sure the bolt pattern matches that of the original block so the PTO accessories, braces and brackets can be bolted on with no modifications. The Kohler Magnum engine models M10, M12, M14 and M16 can be used in any Cub Cadet garden tractor. The majority of the Magnum 10-16hp single cylinder engines have flanges at the base. Therefore, the block will need to be converted into a narrow base by cutting off the flanges on each side and then cut new threads in the holes in the block for the narrow oil pan. And the other parts that's needed are: a K-series large OEM bearing plate with an upper mount gear starter (mounting bolts are below the starter motor), or a small K-series OEM bearing plate with a starter/generator; a small or large diameter K-series flywheel with a matching flywheel shroud and baffle shields (sheet metal); and being there's no provisions for ignition points and no points lobe on the Magnum camshaft, Kohler's Breakerless Ignition or crank trigger ignition will need to be used. Also, because of the 3/8" flywheel retaining bolt, an aluminum clutch hub adapter with a 3/8" hole will need to be used, acquire a 5/8"-3/8" reducer/step washer. (I make these.) Everything else should fit in the tractor with no problems. Only eight models of the 10-16hp Kohler Magnum single cylinder cast iron block engines was manufactured as a narrow base. The specification numbers for these are as follows: M10, specification #'s 461509, 461534 (Cub Cadet garden tractor model 1050); M12, specification #'s 471512, 471514, 471570 (Cub Cadet garden tractor model 1210); M14, specification #'s 601512, 601513; and M16, specification # 711536. All other 10-16hp Magnum engine block specification numbers are a wide base. Any Kohler Magnum single cylinder 10-16hp engine would be excellent to pull with. The only problem is, being these come with solid state ignition, with no provision for ignition points, if a steel flywheel is going to be used, a crank trigger ignition system will be needed, too. Also, if the engine has counterbalance gears, they will definitely need to be removed because one or the other could break, destroying the block and other parts. For most engines, it does absolutely no good to reinstall them. Most Kohler engines don't come with them and in most engines, they do very little to reduce engine vibration. When left out, the engine should not vibrate more than usual. Being balance gears are made of cast iron material and operate [out of balance] on a single, narrow needle bearing for support, they've been known to break and destroy the crankshaft, camshaft and engine block. I've seen this happen to a good engine a few times. Therefore, I highly recommend leaving them out. But if the engine vibrates excessively with the absence of the balance gears, the flywheel and/or crankshaft will need to be dynamically and precision spin-balanced to reduce engine vibration. Click or tap here to learn more about flywheel and/or crankshaft balancing. For a steel flywheel, visit Midwest Super Cub's website. How to Convert a Single Cylinder Kohler K-Series Engine into a Magnum Engine - To convert the Kohler K-series K241, K301, K321 or K341 engine into a Magnum M10, M12, M14 or M16 engine, the parts that's needed are: Magnum OEM bearing plate; starter motor (the support brackets for the starter are for mounting of the starter solenoid only. They do not support the starter motor whatsoever); flywheel (w/external magnet); plastic cooling fan assembly; flywheel shroud; solid state ignition coil w/mounting screws; plastic inner air baffle; cylinder head (cover) and cylinder (side) baffles (sheet metal). The only difference in these baffles is the M10, M12 and M14 all share the same baffles over the cylinder head and on the cylinder, and the M16 use different (larger) baffles. The Kohler points pushrod hole will also need to be plugged with a Briggs & Stratton points plunger plug. And when installing the bearing plate, the cam pin hole will need to be sealed with clear RTV silicone adhesive sealant because the Magnum bearing plate will not cover the hole. By the way - I've always preferred to use clear RTV silicone adhesive sealant for three reasons: Due to metal any warpage (which is unavoidable in most cases), gaskets don't always seal the irregularities and imperfections between mating surfaces, especially thin metal covers; being it's an adhesive, it bonds parts together, forming a leak-proof seal; and being it's clear, a thin bead of silicone makes for a clean and professional-looking repair job. It can't be easily seen or noticed between the parts. FYI - Solid state ignition provides a more stable ignition timing than points ignition. The ignition timing for a K-series engine is less stable because the points operate off the camshaft, which has a tendency to "move around" a few thousandths of an inch while the engine is running, which effects the ignition timing. Flywheel-triggered ignition timing, such as the Magnum solid state ignition, is more stable because it operates off the crankshaft, which doesn't "move around" as much as the camshaft. One thing is lessened and another is gained with either ignition system. 3 1 Share this post Link to post Share on other sites
kpinnc 13,780 #6 Posted June 19, 2022 5 hours ago, Bill D said: Just put the Magnum on unless you really can't stand the look, much easier. Also far simpler. Magneto ignition is dependable and easier to maintain. No points, no coil. Easy peasy. 1 2 Share this post Link to post Share on other sites
RandyLittrell 3,894 #7 Posted June 19, 2022 Okay guys, that tells me all I need to know right there!! If I use it, its staying like it is, I am too old and broken to go to that much work!!!! Randy 3 2 Share this post Link to post Share on other sites
peter lena 9,092 #8 Posted June 19, 2022 @RandyLittrell something not mentioned was VERIFIED ENGINE TIN GROUNDING , you are right there at what ever you come up with, heard it all , you don't have to do that , but a simple cable from battery ground bolt point to engine corner / frame, clutch pedal side serrated washers , dielectric grease , from there to rectifier mount bolt points , there to headlights , amperage gage will also solidly work , this is not difficult . do a test run for ground assurance , have any alligator wire end test wires ? don't guess about your needed related grounding points , verify it with the clip on point to point connection . have that on my 3 horses , bright lights , solid amperage function , instant starts , make your transition , also a problem solver , pete 3 Share this post Link to post Share on other sites
tunahead72 2,518 #9 Posted June 20, 2022 On 6/19/2022 at 8:42 AM, RandyLittrell said: ... If I use it, its staying like it is, I am too old and broken to go to that much work!!!! ... Words to live by right there! 2 Share this post Link to post Share on other sites
