857lover
front weight bracket on 400 series
857lover
hey guys i was wondering if anyone makes a front suitcase weight bracket for the front of a 400 series tractor i am always seeing rear wheel weights everywhere but i don’t ever see stuff for front weight and i wanna see if anyone can make or sells theese because i don’t have any way to make one thanks !:rolleyes:
ebinmaine
Using angle iron you may be able to bolt one together.
I made a front weight bracket for Trina's 867 doing just that.
857lover
yea i thought about it but i want a good fit and finish not looking for perfect would also be cool to have a way to keep them from bouncing around
gwest_ca
Here is what was available
  • Like 5
TonyToro
I’ve made an adjustable front weight bracket using the attach o matic and I’ve made fixed bracket that bolted to the from and could use suitcase weights. I just figured out the cheapest suitcase weights are from my local steel retailer has blanks pre cut and I’m going to Weld on flat steel to them. I’m thinking I can make weights for $4-10 a piece depending on weight versus what nqtp and Midwest sell them for.
TonyToro
Very few …like nearly nobody makes pulling stuff for WheelHorse. Cub cadets get all the attention. Lol
Everyone I meet has made something slightly different.
peter lena
@857lover  couda , shouda , wodua , had related maintenance shops all around our shop set up , ours was a mechanical / weld shop . but when you had to make up a bracket , punch  metal holes , bend and cut any kind of metal , you went to the weld and fabrication shop ,the mechanical advantage benders , were like magic to bend what ever you wanted . basically a drilled heavy pin plate , to set your intended bending work , that and a heavy / long push bar , drop / set pins , to lock in your work ,and do what you needed to do . also had a 150 ton break / cutting press , that would shear heavy s/s plate for work . only wish I could have made more or picked up more "  scrap metal " for home work . like I said , couda shouda wodua , 15 years out , running out of stuff , pete
857lover
yea i would love to add some weight to the front but no one seems to have anything
857lover
pictures? of the fixed and the attach omatic one
TonyToro
I’ll find better pictures but here is one that attached in the attach o matic. It uses box tubing inside a larger box tubing with 2 pieces of solid rod to fit in the mounting holes of the attach o matic and I welded a nut that I can screw the bolt into to lock it in desired position for weight distribution.
I’ll look for the front mounted weight bracket pictures it I’ll just take a picture tomorrow.
sergeant
 Not a Cheap way to do it On My Part at $303.99 Not Including suitcase weights But Many of the components I Bought when Things were a heck of a Lot cheaper
Bought This https://www.ebay.com/itm/131944396619?hash=item1eb87fb74b:g:ux4AAOxyYANTYX55 also Had this already   https://heavyhitch.com/product/sleeve-hitch-adapter-2-inch-receiver/ also Had this https://www.johnnyproducts.com/SleeveHitchAccessories.htm Called a 4X Multi Suitcase weight Pinned weight receiver, so I can put up to (4) 42lb suitcase weight On the front Only used Up to 2 so far  But I can use most of the set-Up with Lowell’s  Hitch https://wheelhorsepartsandmore.com/product/heavy-duty-removable-receive-hitch-if-you-have-a-104659-bracket/ and Have 4 suitcase for the winter when ever I get a front blade for my 416H. Probably will eventually just have a 2inch Insert with weight Bracket Made so I can skip On the sleeve Hitch Insert  and keep the weights a bit closer to the Tractor
Edited by sergeant
857lover
do you have a picture by chance ??
C-85
Here's my version, this is independent of the plow and hitches to the Tach a Matic front mount, I made this myself -
C-85
This is what it looks like off the tractor -
  • Excellent 3
peter lena
@C-85  thats not fair !  working in the kitchen , does not count , you get no points for that !  I  also have a c-85 , bought it new in 82 , recently  celebrated over 40 years with it ,  did a 12 horse magnum swap a few years ago , still my favorite  of my 3 horses ,  has all my experimentation ideas on ending chronic problems on it . dr frankenhorse , AKA , greasy pete
  • Haha 1
C-85
I'm sorry that there's no fairness :angry-tappingfoot: :) , perhaps we need to all think more about the DEPARTMENT OF THE INTERIOR !
C-85
FullPull!
Check out a makerspace near you; they usually have tools/equipment available that you could use to fabricate your own.
Looks like this one might be local to you: https://make717.org/
Lee1977
These will fit any Wheel Horse with the front hitch. I used a 5/8" bolt because I had it, 5/8' rod will work just as well. I used a 2x2x1/4 angle a flat plate will work also.
Your a couple years late can't see to weld anymore
CCW
@857lover Pictured is a bracket I just finished this winter for my 312-8 to have a new winch and hang suitcase weights on.  Purchased a 3x12x1/2 inch piece of steel ($32.00) and welded it to two pieces of angel Iron to bolt to the sides of the frame's front.  I also added some spacers under the angle iron to allow enough space for the mule drive.
Edited by CCW
