chev0545 234 #1 Posted June 10, 2022 on a 314 hydro with the out of gear lever suddenly quit moving.could it have come unhooked? Share this post Link to post Share on other sites
953 nut 56,753 #2 Posted June 10, 2022 1 hour ago, chev0545 said: out of gear lever suddenly quit moving Do you mean to say the motion controller is not going to neutral when the brake is applied? If that is the case the rod from the brake to the cam inside the tunnel where the motion controller is located has become disconnected. Share this post Link to post Share on other sites
chev0545 234 #3 Posted June 11, 2022 i'm talking about the cold start lever Share this post Link to post Share on other sites
chev0545 234 #4 Posted June 11, 2022 on a 314 hydro it suddenly stopped moving.would the cold start lever be unhooked? 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #5 Posted June 11, 2022 1 hour ago, chev0545 said: i'm talking about the cold start lever Do you mean the "choke" lever? Share this post Link to post Share on other sites
Handy Don 13,085 #6 Posted June 11, 2022 Do you mean the clutch that loosens the drive belt from the engine so you can push the tractor more easily? Share this post Link to post Share on other sites
chev0545 234 #7 Posted June 11, 2022 the drive belt Share this post Link to post Share on other sites
Handy Don 13,085 #8 Posted June 11, 2022 There is a bolt that connects that lever to the drive belt tensioner arm. Its behind the belt guard on the right side. Not a difficult repair. 1 Share this post Link to post Share on other sites
953 nut 56,753 #10 Posted June 11, 2022 (edited) 11 hours ago, chev0545 said: suddenly stopped moving.would the cold start lever be unhooked? Is this the same problem you posted yesterday and got several responses to? Need a bit of clarification here. Does "Suddenly stopped moving" mean the engine quit running or does it mean the engine is running but the tractor quit moving? Is the "cold start lever" the choke? If so, how would this be connected to "Suddenly stopped moving"? Edited June 11, 2022 by 953 nut 3 Share this post Link to post Share on other sites
chev0545 234 #11 Posted June 11, 2022 tractor stopped moving motor runs Share this post Link to post Share on other sites
