PK-2mow
Governor shaft
PK-2mow
How much turn avaiable in the governor shaft of a K321 14hp engine.
Edited by PK-2mow
Not enough info
wallfish
:WRS:
Not much, maybe 1/8 of a full turn. It only needs to move the connected arm enough for the full motion of the carb butterfly
Edited by wallfish
  • Thanks 2
squonk
If it turns a lot  (like all the way around) the tab is broken inside. You will need to completely tear the engine down to repair.
Edited by squonk
  • Sad 1
