Wayne0 457 #176 Posted August 29 I'm not allowed to paint in the kitchen.............. 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #177 Posted August 29 52 minutes ago, Wayne0 said: I'm not allowed to paint in the kitchen.............. I'm not allowed to paint. At all.... 2 Share this post Link to post Share on other sites
kpinnc 12,023 #179 Posted August 29 7 hours ago, Wayne0 said: I'm not allowed to paint in the kitchen.............. If you really wanna start something, heat some parts in the oven... Ask me how I know! 3 Share this post Link to post Share on other sites
ebinmaine 67,484 #180 Posted August 29 Our good friend that does truck fabrication for a living was telling us all about the amazing qualities of anaerobic sealer and how they've pretty much switched over to using that almost exclusively. I bought some so they could use it on my truck when we rebuild the rear axle. I got thinking that might be good in the application here for trying to seal up the valve cover. I didn't realize that it can't be laid down on top of paint so I scraped the painted surface under the gasket for the breather off with a razor and then some sandpaper and then cleaned it with brake clean on a rag. Put the new base gasket in. All installed and setting to dry. 1 4 Share this post Link to post Share on other sites
Moparfanforever 844 #182 Posted August 31 Looks like you have a spacer on the front of the hood?? I am curious about the sealer you are talking about ,is it better than RTV?? Thanks!! 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #183 Posted August 31 5 minutes ago, Moparfanforever said: Looks like you have a spacer on the front of the hood?? That's original Wheelhorse parts. They had to install the taller hood hinge to clear the taller engine. 5 minutes ago, Moparfanforever said: I am curious about the sealer you are talking about ,is it better than RTV? First time we've used it. According to our friend it's easier to use and holds better. 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #184 Posted September 3 The Paint RESTORATION Department AKA BBT helped me give this horse a good cleaning with Dawn and 3M Scotch Brite 7447 regular duty pads. The Paint is.... meh.... at best. I MIGHT decide to go further with a finer grit paper later. No time this week. 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #186 Posted September 6 The Paint Department also got the seat springs cleaned up, derusted, and painted, and all mounted. Yes I know they're "backwards" I like the lean to be forward, not tilting back off the tractor. And.... I'm backwards too. 1 1 Share this post Link to post Share on other sites
8ntruck 6,999 #187 Posted September 6 the level you out going uphill, right? 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #188 Posted September 6 Just now, 8ntruck said: the level you out going uphill, right? This seat is kinda tilted forward.. and the springs being reversed cause a back tilt. And I'm still tilted. Share this post Link to post Share on other sites
