elcamino/wheelhorse
Log spliter help
elcamino/wheelhorse
My son has a Huskee (Husky ) spliter , 35 ton , 12.5 Hp vertical shaft B&S motor. It is leaking from the pump. There is not  a model number any where on the spliter . Found part of a tag on the pump  it looks like "Malb__  next word M _____   ,  I can read Rockford, Il.  110104 . Does any body have a spliter like this or know any thing about the pump or the company that made ?  My son and his 4 buddies purchased about 4 or 5 years ago . (the 4 buddies was his first mistake ) . I can't find a parts manual  on the spliter or any information on the pump. No idea on GPH rating on the pump.
Pullstart
Maybe tell him to swing it harder and it’ll still work? :confusion-confused:
:ROTF:
  • Haha 2
1995 520H+96+97
  • Sad 1
Pullstart
$1226 for a pump alone!?!?!?  I’d customize it to fit something else.
elcamino/wheelhorse
Every manual I have found is for a horizontal shaft engine . I checked that $1,226.00 and it is for a horizontal shaft engine.. The log spliter my son has is a vertical/horizontal unit if that makes any difference.  I think if I could find the specs on the pump that is on the unit , I could find a pump to purchase. Not paying $1,226 for a pump.
squonk
There has to be a hydraulic repair shop near you somewhere. Have him horse that pump off and take it to to one. It will probably be cheaper to buy a new splitter!
https://www.hescorva.com/
https://www.pirtekusa.com/locations/west-end/
http://www.afpind.com/
lynnmor
Perhaps this might help.  Measure your shaft and mounting and give these guys a call.
elcamino/wheelhorse
Thanks guys , would like to find a manual , so I can figure out what needs replacement. There has to be some kin of coupler etc between engine shaft and pump shaft .  Can't see squat as to where everything mounts. would like some kind of idea of what I am dealing with before I tear into it.
Achto
 I believe that the Huskee log splitter was actually manufactured by Speeco, looks identical. If the below manual don't help try looking up a Speeco 35 ton splitter.
https://www.tractorsupply.com/static/sites/TSC/downloads/ProdContentPDFs/1083954_Man1.pdf
Should be a love/joy connector.
