elcamino/wheelhorse 9,317 #1 Posted June 6, 2022 My son has a Huskee (Husky ) spliter , 35 ton , 12.5 Hp vertical shaft B&S motor. It is leaking from the pump. There is not a model number any where on the spliter . Found part of a tag on the pump it looks like "Malb__ next word M _____ , I can read Rockford, Il. 110104 . Does any body have a spliter like this or know any thing about the pump or the company that made ? My son and his 4 buddies purchased about 4 or 5 years ago . (the 4 buddies was his first mistake ) . I can't find a parts manual on the spliter or any information on the pump. No idea on GPH rating on the pump. Share this post Link to post Share on other sites
Pullstart 62,905 #2 Posted June 6, 2022 Maybe tell him to swing it harder and it’ll still work? 1 2 Share this post Link to post Share on other sites
Pullstart 62,905 #4 Posted June 6, 2022 $1226 for a pump alone!?!?!? I’d customize it to fit something else. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,317 #5 Posted June 6, 2022 Every manual I have found is for a horizontal shaft engine . I checked that $1,226.00 and it is for a horizontal shaft engine.. The log spliter my son has is a vertical/horizontal unit if that makes any difference. I think if I could find the specs on the pump that is on the unit , I could find a pump to purchase. Not paying $1,226 for a pump. Share this post Link to post Share on other sites
squonk 41,149 #6 Posted June 6, 2022 There has to be a hydraulic repair shop near you somewhere. Have him horse that pump off and take it to to one. It will probably be cheaper to buy a new splitter! https://www.hescorva.com/ https://www.pirtekusa.com/locations/west-end/ http://www.afpind.com/ Share this post Link to post Share on other sites
lynnmor 7,307 #7 Posted June 6, 2022 Perhaps this might help. Measure your shaft and mounting and give these guys a call. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,317 #8 Posted June 7, 2022 Thanks guys , would like to find a manual , so I can figure out what needs replacement. There has to be some kin of coupler etc between engine shaft and pump shaft . Can't see squat as to where everything mounts. would like some kind of idea of what I am dealing with before I tear into it. Share this post Link to post Share on other sites
Achto 27,600 #9 Posted June 7, 2022 2 hours ago, elcamino/wheelhorse said: would like to find a manual , so I can figure out what needs replacement. I believe that the Huskee log splitter was actually manufactured by Speeco, looks identical. If the below manual don't help try looking up a Speeco 35 ton splitter. https://www.tractorsupply.com/static/sites/TSC/downloads/ProdContentPDFs/1083954_Man1.pdf 2 hours ago, elcamino/wheelhorse said: There has to be some kin of coupler etc between engine shaft and pump shaft . Should be a love/joy connector. 1 1 Share this post Link to post Share on other sites
