JerryLook
Toro/Wheel Horse 15-48SC-02 blades
JerryLook
I’m looking for new blades for this deck. The ones that are on it right now are about 15 3/4” long.
I can’t find the manual for the 15-48SC-02, but I can find the manual for the 15-48SC-01. It calls out for a 14” blade. Is that same manual applicable to my deck?
Also if I was just going to grab some blades from Ace down the road, are these 5/8” or 3/4” spindles?
Thanks
JerryLook
When I look at blades online it shows the 14” blade is for a 42” wide deck and a 16” blade is for a 48” wide deck.
Also I see low lift, standard lift, and high lift blades. I cut long and sometimes slightly wet grass. So from what I’ve read I want high lift blades.
Edit:
Lol I wasn’t thinking about if it’s a 48” cut, the blades have to be at least 16”. Because 16+16+16=48.
Edit #2:
I found some blades (Oregon OR-91-806) for 10 bucks each. Total would be 40$ including shipping. But they’re standard lift. These are 16” blades.
Edited by JerryLook
