Liberty work shop
Single stage snow thrower on 520H
Liberty work shop
Hi all . I'm Liberty Work Shop and I've been rebuilding and restoring garden tractors for many years . Have a question .I just watched a video on you tube where the guy installed a toro single stage snow thrower on a 520H and my question is this , does that blower have a reversing gearbox on it , or how does it turn the right way ? The engine turns CCW looking at the PTO and the thrower shaft has to turn CW , looking at it from the same side . Or am I just missing something ? Any help would be welcome ... Thanks
roadapples
:WRS:
gwest_ca
Welcome to the forum.
The drive chain does not go around the sprocket on the auger. It goes under it.
Liberty work shop
Ok . Cool , it's all clear to me now , L O L . I figured the direction change was done with the drive belt somehow . I am getting ready to reconfigure a Bolens single stage for my 520H ...Now I know what I need to do to effect the rotation change . Thanks very much .
Handy Don
This is one of the cleverer bits of engineering I've seen and wondered what inspired it.
I've since seen an early chain drive for a "motor car" that used three chains continuously engaged -- two for forward speeds and one with idlers that gave them reverse. No gearbox. A slider on the "drive" shaft engaged one drive sprocket at a time. I'm thinking it was bicycle mechanics that dreamed it up!
Liberty work shop
Yes ... Someone certainly had their thinking cap on when they came up with this ... So simple yet ..........
