TonyBer 71 #1 Posted June 5, 2022 Fun stuff, I had a snow plow on my 8hp and then later picked up a C160 for a snow blower. I put mower decks on both. Honestly, the 8hp mows like a champ and plowed anything I asked of her. But......the 160 is a smooth beast and wouldn't want to be in her way. Both are a joy...overkill but I think I'll keep both. 3 7 Share this post Link to post Share on other sites
rjg854 11,710 #2 Posted June 5, 2022 I have no idea on how much you're mowing, but if you're only mowing a little bit an 8hp only sips gas, where that 16 is going to really suck gas on you. I have an 8hp and a 160 also that I mow with and the difference in gas consumption is quite impressive. 9 Share this post Link to post Share on other sites
Sparky-(Admin) 21,743 #3 Posted June 5, 2022 I alternate between a 308-8 with a 36” deck, a 315-8 with a 42” deck and my GT-3000 with a 46” deck and triple bagger. Takes a bit longer with the 308 but it definitely uses way less fuel! And I enjoy mowing so I don’t care about shortening my mowing time 6 Share this post Link to post Share on other sites
buckeyes 214 #4 Posted June 5, 2022 Those magnum 8's are great little workers! 2 Share this post Link to post Share on other sites
squonk 41,940 #5 Posted June 5, 2022 I mow a third of an acre. I love the hydro for mowing on the C-160 but the little 857 saves a quart of gas each time and turns sharper. Plus the gear drive deck makes a pristine cut! 4 4 Share this post Link to post Share on other sites
ri702bill 8,743 #6 Posted June 5, 2022 1 hour ago, Sparky said: And I enjoy mowing so I don’t care about shortening my mowing time Mowing to the sound of a sweet running K series single cylinder is the music that makes all the rest not matter... Bill 3 1 Share this post Link to post Share on other sites
ebinmaine 69,711 #7 Posted June 6, 2022 15 hours ago, TonyBer said: overkill Overkill is in the eye of the beholder... Or something like that. 2 2 Share this post Link to post Share on other sites
chip61 664 #8 Posted June 6, 2022 Nice looking machines!! C160 hydro is my favorite. Not quite as bad on gas as the 416H Onan. I cut several acres and really should get a zero, but I prefer tractors. 2 Share this post Link to post Share on other sites
Docwheelhorse 2,684 #9 Posted June 6, 2022 2 hours ago, ebinmaine said: Overkill is in the eye of the beholder... Or something like that. I don't much care about the MPG my 'Horse gets... gimme the K341 Thump all day 3 1 Share this post Link to post Share on other sites
ohiofarmer 3,314 #10 Posted June 6, 2022 (edited) Depending on the time of the year, horsepower matters. once July hits, a ten or twelve horsepower works. A 12 with hydro is pretty much maxxed out at the similar speed of a manual. Once the tough seedheads are gone and the grass thins out, then take your pick,I guess. But come on, a c-160 is a thumper with a 48 inch deck. Still, the toughest machine I have that takes on the high grass is just ten horsepower, but because the side drive deck hooks up so solid with the shorter belt, i can take down the much taller grass without heating up the belt like a mule drive does Edited June 6, 2022 by ohiofarmer 1 Share this post Link to post Share on other sites
clueless 3,075 #11 Posted June 6, 2022 1 hour ago, ohiofarmer said: Depending on the time of the year, horsepower matters. once July hits, a ten or twelve horsepower works. A 12 with hydro is pretty much maxxed out at the similar speed of a manual. Once the tough seedheads are gone and the grass thins out, then take your pick,I guess. But come on, a c-160 is a thumper with a 48 inch deck. Still, the toughest machine I have that takes on the high grass is just ten horsepower, but because the side drive deck hooks up so solid with the shorter belt, i can take down the much taller grass without heating up the belt like a mule drive does Depends on where you live and what type of grass you have. My 1974 B80 4sp cut my 3/4 acer of centipede 1 3/4 inches, down here in the south every 10 to 12 days from May through Sept. for 20+ years just fine. I do like my C160 Auto with the 42 inch deck it cuts great also just faster. 1 Share this post Link to post Share on other sites
