Mike C160
1977 C160 Auto... Pieces.
Mike C160
@ebinmaine yes it actually is a small pebble that fell in off the top of the case as it was split in situ.
ebinmaine
9 minutes ago, SylvanLakeWH said:
A Haiku…
Confucius wise man
@ebinmaine claimed so
Consult Colossus
:ychain:
A haiku...
If it's worth doing
It's worth doing tomorrow
So says The Large Bear
:ROTF:
  • Haha 3
  • Heart 1
Mike C160
Ok
Need some words of wisdom.
Is there a good tutorial on removing and installing these needle bearings? Or in the alternative someone with experience at removing and installing these bearings?
By better judgement is telling me to replace all the bearings in that case. And if there is a simple way to remove them I will.
So i will have to order parts from lowell and it will take at least two weeks for them to arrive. So I have some time to get some tools and a good procedure in place.
Any words of wisdom would be appreciated.
Cheers
ebinmaine
The bearing and outer shield are one piece.
Right or wrong... I've used a socket of very close diameter as a driver.
  • Like 5
Mike C160
I see that now!! That makes it easy!
I thought it was a blind hole I had to slide them out of.
Maxwell-8
43 minutes ago, Mike C160 said:
1) Left side inner axle bearing 1533 Partial failure / full on failure in progress.
2) Right side mushroom gear needle bearing.
I have seen broken needle bearings destroy those ball bearings.
Edited by Maxwell-8
pfrederi
 Your parking pawl is shot..  Somebody kept engaging it while still in motion.  A to Z can probably fix you up with  good used one...  I also use a close size socket to drive out bearings.
Maxwell-8
Great point, also a good idea to drive in bearings
DSC_1156.JPG.8518ad01576e05d1f0fb4b2e2bc68312.JPGDSC_1158.JPG.6e99b879122cca02111317c97d8e39ae.JPG
  • Like 4
Mike C160
I saw it was pretty chewed.  I dont think im gonna worry about it right now. It takes many weeks to get stuff from A to Z for me.
I think im going to order all new bearings and seals and call it a day.
Thanks.
Mike C160
So the next big question.
The machine is a 1977 C160 auto and I dont have a parts manual for it.
I do have the 1975 C160 Auto parts manual. Is it ok to get my part #'s out of this manual?
Cheers
ebinmaine
Cheers
Should be the same...
Lowell will have the numbers for the bearings.
I'm very curious to know why it takes so much longer to get stuff from Pennsylvania than it does from Michigan or whatever.
Mike C160
No idea.
I ordered from A to Z long ago. It shipped right away. Its still not here. Its been 3 weeks. Yet stuff from lowell takes about 14 days.
Cheers
Mike C160
Ok,
250 bucks later, Ive ordered all the parts. All bearings and seals. May as well completely freshen it up completely. Cept the parking brake pawl. Not really concerned about that right now. Too hard / long to source one. Unless someone just happens to have one hanging around.
So now we wait.
ebinmaine
10 minutes ago, Mike C160 said:
pawl
Check eBay Canada. Never know.....?
Mike C160
Ordered a bearing puller set to get those 1533s out.
  • Like 6
Mike C160
Did you find you needed that jig to install the axle bearings? Cant just gingerly tap them into place??
Great home brew jig by the way.
Cheers
Maxwell-8
Thanks,  You can, I have done a couple with success but I have also broken one by hammering it in. Had to go out order a new bearing and then made this jig. It insures a more strait install and protects the roller from locking.
Maxwell-8
I had an old set laying around, a must have to remove bearings or left overs like here:
Mike C160
Gotcha. Prolly best plan is to start with wood until the brg is well inserted and then level it off with some gentle taps from the knock-ometer. :)
Maxwell-8
If you are going to use a hammer, go for a rubber hammer, I think it's softer on the bearing.
ebinmaine
That's what I usually do. A closet clothing pole works well.
We use nylon sand filled dead blow hammers. They don't bounce like rubber hammers.
Much easier to control the concussion.
Mike C160
Yep. I think i got a nylon knock-ometer around here somewhere :)
ebinmaine
I s'pose a wood 🪵 stick would work too.
Mike C160
@pfrederi
Would wouldnt happen to have a standard part number for the Orings that go on the hydraulic lines right at the pump would you???
Thanks and Cheers..
Mike C160
Got my bearing puller set today.
All bearings are out and case clean up has begun.
Lowell shipped parts today.
