Pullstart 62,857 #26 Posted June 4, 2022 (edited) I don’t know his name yet, but he’s kissing on Chloe! *edit* Named him Colt. Edited June 4, 2022 by Pullstart 1 1 1 Share this post Link to post Share on other sites
Pullstart 62,857 #27 Posted June 4, 2022 I found that this machine takes a Transmission drive belt 8334 - (B x 84.8" or 5/8" x 84.8") per the manuals section. I’ll look to see if I have a NOS belt, but otherwise I’m not sure if I’ll be able to find an 84.8” belt. Do I go 84” or 85”? @gwest_ca? Share this post Link to post Share on other sites
953 nut 55,224 #28 Posted June 4, 2022 I have used a Kevlar 5/8 X 85" (5L-850) (B-82) from tractor supply on mine with good results. 1 Share this post Link to post Share on other sites
Pullstart 62,857 #29 Posted June 4, 2022 24 minutes ago, 953 nut said: I have used a Kevlar 5/8 X 85" (5L-850) (B-82) from tractor supply on mine with good results. The snowmotractor could use a 1” shorter belt, if not 2”. It has an 84” belt on it. I might just try that on the GT14 and see if it works well or not 1 Share this post Link to post Share on other sites
953 nut 55,224 #30 Posted June 4, 2022 2 minutes ago, Pullstart said: 84” belt on it. I might just try that on the GT14 The worst that could happen is you find out it won't work and spent a couple minutes trying. 1 Share this post Link to post Share on other sites
Pullstart 62,857 #31 Posted June 4, 2022 2 hours ago, 953 nut said: The worst that could happen is you find out it won't work and spent a couple minutes trying. The 84” is working swimmingly! 2 3 Share this post Link to post Share on other sites
Pullstart 62,857 #32 Posted June 4, 2022 It’s pretty amazing what a ‘63 and ‘69 are still capable of! The surrounding weed growth is from 2 years of no garden plot. I dragged it a bit with the cultivator, plowed, disced, cultivated, then tilled. Probably could cultivate once more before sticking the ‘maters in! 3 1 Share this post Link to post Share on other sites
Pullstart 62,857 #33 Posted June 4, 2022 (edited) On the end of my first pass, my lower lift pin was in the way of the steering fan gear, so I couldn’t turn left. I need to swap the pins, the second one I made on the rear is much shorter. Edited June 4, 2022 by Pullstart 1 5 1 Share this post Link to post Share on other sites
PeacemakerJack 10,738 #34 Posted June 4, 2022 Good video Kevin, that thing is really working well. I’m impressed with how good the ground looks after your passes😎🙌🏻 2 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,641 #35 Posted June 5, 2022 Outstanding work. And the video quality is always improved by mounting the camera on a Wheel Horse, too! Nice. 1 1 Share this post Link to post Share on other sites
953 nut 55,224 #36 Posted June 5, 2022 1 hour ago, Pullstart said: I couldn’t turn left. Couldn't turn LEFT. How tragic for a stock car racer to not be able to turn left. 1 3 Share this post Link to post Share on other sites
Pullstart 62,857 #37 Posted June 5, 2022 5 minutes ago, 953 nut said: Couldn't turn LEFT. How tragic for a stock car racer to not be able to turn left. it hurt. A lot. 2 Share this post Link to post Share on other sites
EB-80/8inPA 1,641 #38 Posted June 5, 2022 @ebinmaine I suspected you’d appreciate that. But how about this Hosen Puller guy, anyway? How on earth does he do it? He makes things look so easy! 1 2 Share this post Link to post Share on other sites
ebinmaine 67,484 #39 Posted June 5, 2022 7 hours ago, EB-80/8inPA said: @ebinmaine I suspected you’d appreciate that. But how about this Hosen Puller guy, anyway? How on earth does he do it? He makes things look so easy! That's a young feller with multi talents!! 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,557 #40 Posted June 5, 2022 He forgot pics…game cam caught him in action… 6 Share this post Link to post Share on other sites
jeremi3210 717 #41 Posted June 5, 2022 Very nice! I've got 2 gt14's and would love find a tiller for one! Very strong and capable tractors. I made both my 3 points independent from my mid lift. I can mow lawn and move trailers with out even leaving my seat! 1 3 Share this post Link to post Share on other sites
Pullstart 62,857 #42 Posted June 5, 2022 @jeremi3210 I’m guessing those ags are 953 wheels and tires? Mind sharing the details of the other ones? Share this post Link to post Share on other sites
Sparky-(Admin) 21,315 #43 Posted June 5, 2022 So I’ve owned a couple D series and a couple 1054’s and although they are “bigger” they seem to lack room for the operator. They feel cramped. I think my C series machines are more comfy. How does the GT-14 compare? Leg room and comfort? Share this post Link to post Share on other sites
jeremi3210 717 #44 Posted June 5, 2022 1 minute ago, Pullstart said: @jeremi3210 I’m guessing those ags are 953 wheels and tires? Mind sharing the details of the other ones? Yes the 6.70 15 ags were a set of 953 wheels I had picked up cheap! The others are skid steer wheels I mounted on gt14 rims. Ag tires are almost impossible to find in that size unless you run across some old ones. Can't remember the size off hand but they are correct for the tractor. 2 Share this post Link to post Share on other sites
Pullstart 62,857 #45 Posted June 5, 2022 7 minutes ago, Sparky said: So I’ve owned a couple D series and a couple 1054’s and although they are “bigger” they seem to lack room for the operator. They feel cramped. I think my C series machines are more comfy. How does the GT-14 compare? Leg room and comfort? Well… you’re asking a little short guy if there’s enough room! They have cool little notched plates on the back of the seat to be able to lift the seat, move it forward or backward then set it into another notch. For now, I took the seat off and tossed a steel pan over the hydro hole. I thought about adding a 953 style seat and backrest 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,315 #46 Posted June 5, 2022 2 minutes ago, Pullstart said: Well… you’re asking a little short guy if there’s enough room! LOL! Didn’t consider that . I’m 6-1” and kinda long in the leg so I feel cramped on some machines. Maybe I’ll find some kind soul at the show that will let me sit on their GT-14! 1 Share this post Link to post Share on other sites
Pullstart 62,857 #47 Posted June 5, 2022 The girls visited me in the shop last night. When momma’s out of town, they do a pretty good job making sure I eat, drink, sleep, etc. We discussed Colt’s exhaust system. It sounds great but blows straight down… not my favorite. I think we (they) decided that we will for sure utilize “Steve”s old tailpipe. It might take a couple cuts and turns and welds, but it’s pretty much all there! Remember too that there is a home built muffler inside this pipe. 4 Share this post Link to post Share on other sites
Bow_Extreme 544 #48 Posted June 5, 2022 Going to town on that thing! Very Nice! 1 Share this post Link to post Share on other sites
jeremi3210 717 #49 Posted June 5, 2022 (edited) Them tires are 27 8.50 15 skid steer. I've found them at flea markets pretty cheap. Seem to get great traction Jacob was plowing with them on his 953 at Jim's last year and the year before with no problems! Edited June 6, 2022 by jeremi3210 1 Share this post Link to post Share on other sites
Aldon 4,826 #50 Posted June 6, 2022 On 6/5/2022 at 5:31 AM, jeremi3210 said: Very nice! I've got 2 gt14's and would love find a tiller for one! Very strong and capable tractors. I made both my 3 points independent from my mid lift. I can mow lawn and move trailers with out even leaving my seat! I have a tiller I'd sell ya but I am in Idaho. Not sure when I would next end up driving east but I do have the goal of hitting the show next year. 2 2 Share this post Link to post Share on other sites
