TonyToro 1,085 #1 Posted June 2, 2022 Is anyone here diesel savvy? Anyone know a mobile mechanic? Or live close to me and want to get it running? We have a mid 1960’s Minneapolis Moline backhoe. It ran last year. It sat and now won’t start. I cleaned out all the lines leading up to the injection pump. Most of the lines had like a tar type substance. I have also cleaned out the fuel tank. I’m at the point where I need to get into the injection pump. I’ve never taken one of these apart. I’m sure I can I’m just reluctant. Any tips, tricks or help is appreciated. Share this post Link to post Share on other sites
WHX?? 49,919 #2 Posted June 2, 2022 (edited) Funny you should post this Tony. I too have what we believe to be a MF-30 industrial tractor that started last year. Recently tried to start it but no go. Used to go with a quick shot of sniffing salts but not now. Manual says might be air in injector/pump but bled them per manual and looked to be good fuel coming out of bleed ports . Thinking injector timing or pump bad ? But how does it go bad just sitting ther? 3 jug Perkins diesel .... 84 or so vintage. Be interested in what those who know say. @Pullstart @Achto and others. Edited June 2, 2022 by WHX?? 1 Share this post Link to post Share on other sites
TonyToro 1,085 #3 Posted June 2, 2022 30 minutes ago, WHX?? said: Funny you should post this Tony. I too have what we believe to be a MF-30 industrial tractor that started last year. Recently tried to start it but no go. Used to go with a quick shot of sniffing salts but not now. Manual says might be air in injector/pump but bled them per manual and looked to be good fuel coming out of bleed ports . Thinking injector timing or pump bad ? But how does it go bad just sitting ther? 3 jug Perkins diesel .... 84 or so vintage. Be interested in what those who know say. @Pullstart @Achto and others. No kidding…that is funny that we both have similar issues. Ours used to start in any temperature and nearly instantly. I’ve been told there is a screen on the top of the injection pump. It’s “just” gel’d up. Clean it and should be good. Lol sounds simple enough but…I haven’t done it. Share this post Link to post Share on other sites
Pullstart 63,529 #4 Posted June 2, 2022 I haven’t done a ton of diesel tractor service. I have a diesel small engine that won’t fire on juice either. I haven’t done a ton of true investigation yet. 1 Share this post Link to post Share on other sites
WHX?? 49,919 #5 Posted June 2, 2022 What motor Tony? 9 minutes ago, TonyToro said: It’s “just” gel’d up. Clean it and should be good. Lol sounds simple enough but…I haven’t done it. Giterdone .... mine has a epoxy glued on oil heater on the pan that helps in cold but it has been in the 70s here so I doubt that's an issue. I used diesel treatment so doubt that's an issue too. 1 Share this post Link to post Share on other sites
TonyToro 1,085 #6 Posted June 2, 2022 19 minutes ago, WHX?? said: What motor Tony? Giterdone .... mine has a epoxy glued on oil heater on the pan that helps in cold but it has been in the 70s here so I doubt that's an issue. I used diesel treatment so doubt that's an issue too. I tried to start it last weekend when it was around 90. I figured the same… we have conditioner in it and the hot temperature it should have started. ok I’m working up to fix this thing. It won’t be tomorrow, TonyToro JR. is making me take him to buy a Disc harrow. I’ll try Friday. I still would rather someone just wave their magic wand over it and me hand some cash after it’s running. 1 Share this post Link to post Share on other sites
Achto 28,190 #7 Posted June 2, 2022 1 hour ago, WHX?? said: Be interested in what those who know say. Could be air locked between the bleeder and the injectors. Try cracking all the lines where they go into the injectors and bleed the fuel to that point. 3 1 1 Share this post Link to post Share on other sites
peter lena 8,970 #8 Posted June 2, 2022 @TonyToro @https://tap.fremontmotors.com/what-is-diesel-gelling-and-how-to-stop-it/#:~:text=How do you know if your diesel is,(if you have a gauge that displays this) don't have a diesel , but that gelling is a common problem , found a number of related sites , the correct fuel additive , in addition to filter changes , block heaters etc . definitely help out , snoop around , pete 2 Share this post Link to post Share on other sites
TonyToro 1,085 #9 Posted June 2, 2022 15 hours ago, Achto said: Could be air locked between the bleeder and the injectors. Try cracking all the lines where they go into the injectors and bleed the fuel to that point. Yes that’s what I was hoping for but I opened all of them and I have fuel on the return side but not feed side. 1 Share this post Link to post Share on other sites
squonk 41,939 #10 Posted June 2, 2022 (edited) Edited June 2, 2022 by squonk 1 Share this post Link to post Share on other sites
TonyToro 1,085 #11 Posted June 3, 2022 I 2 hours ago, squonk said: I put something similar in the tank back in November. I think it was the same band as the first picture just with 911 in the name. No luck yet. Lol Share this post Link to post Share on other sites
oliver2-44 10,075 #12 Posted June 3, 2022 You might try disconnecting a line on the outlet side of the pump and the at the injector inlet. See if you can spray something like wd40 thru it to determine if the lines are gummed/gelled up. If the line is clear time to investigate the pump. I’m no expert but I pulled the injector pump on my old Oliver several years ago and replaced the front pump seal. I have a manual and it was actually simple to keep pump timed. 1 Share this post Link to post Share on other sites
TonyToro 1,085 #13 Posted June 3, 2022 14 hours ago, oliver2-44 said: You might try disconnecting a line on the outlet side of the pump and the at the injector inlet. See if you can spray something like wd40 thru it to determine if the lines are gummed/gelled up. If the line is clear time to investigate the pump. I’m no expert but I pulled the injector pump on my old Oliver several years ago and replaced the front pump seal. I have a manual and it was actually simple to keep pump timed. Awesome! I’ll give that a try tonight. Im going to dive into it since I’ve called 9 repair guys in the past 2 weeks and no one calls back. I guess I’ll have to see what I can do. Can’t break it any more I guess. I think I found the replacement injection pump if it doesn’t end up working. Share this post Link to post Share on other sites
oliver2-44 10,075 #14 Posted June 3, 2022 (edited) 24 minutes ago, TonyToro said: . I think I found the replacement injection pump if it doesn’t end up working. Before you buy a new one $$$. There should be some shops that specialize in repair/rebuilding injector pumps. I searched your area and found Metro Fuel Injection. Edited June 3, 2022 by oliver2-44 Share this post Link to post Share on other sites
