Bucks 31 #26 Posted June 28, 2022 Thanks to all you guys ! My Raider 9 is alive for the first time in 27 years! Still need to rebuild carb or replace but she runs and sounds good! original gas tank leak at shut off valve . very slight , are new valves available or possible repair kits? Now I really need a bourbon to celebrate thanks guys 1 2 Share this post Link to post Share on other sites
ebinmaine 67,484 #27 Posted June 28, 2022 2 minutes ago, Bucks said: Thanks to all you guys ! My Raider 9 is alive for the first time in 27 years! Still need to rebuild carb or replace but she runs and sounds good! original gas tank leak at shut off valve . very slight , are new valves available or possible repair kits? Now I really need a bourbon to celebrate thanks guys Glad to hear! Yes you can get those valves. Do you have a plastic tank with the pop in grommet or a metal tank with the screw in type? Either way they're available. Try to clean your own carburetor instead of replacing it. The modern ones just don't hold a candle to the old stuff. 3 Share this post Link to post Share on other sites
Bucks 31 #28 Posted June 28, 2022 Medal tank Thanks 2 Share this post Link to post Share on other sites
Bucks 31 #29 Posted June 28, 2022 do you know where? 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #30 Posted June 28, 2022 Just now, Bucks said: Medal tank Thanks If your valve isn't too rusted up you can remove the nut where the twisting stem goes in and sometimes replace that o-ring 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #31 Posted June 28, 2022 Just now, Bucks said: do you know where? Yeah they're available all over the interwebs. Give me a couple hours here and I'll get you a source or I could even send you one if you PM me your address 1 Share this post Link to post Share on other sites
Bucks 31 #32 Posted June 28, 2022 cool thanks no hurry 1 Share this post Link to post Share on other sites
Bucks 31 #33 Posted June 28, 2022 address is 10648 Lawndale Chicago il. 60655 Let me know if you send one and what I owe ya. another question is that original cutting decks for this tractor all show 3 blades mine is only 2,deck is about 36 inches wide rear discharge any thoughts? blades need replacing 2 Share this post Link to post Share on other sites
ebinmaine 67,484 #34 Posted June 29, 2022 13 hours ago, Bucks said: address is 10648 Lawndale Chicago il. 60655 Let me know if you send one and what I owe ya. another question is that original cutting decks for this tractor all show 3 blades mine is only 2,deck is about 36 inches wide rear discharge any thoughts? blades need replacing I'll get one packaged up and sent out in the next few days here. We don't mow with any of our Horses so I'm not familiar with the setups. I can tell you that the decks and other implements have a wide year range of coverage. Share this post Link to post Share on other sites
Bucks 31 #35 Posted June 29, 2022 ok thanks a lot 1 Share this post Link to post Share on other sites
Bucks 31 #36 Posted June 29, 2022 have a great 4th! 1 Share this post Link to post Share on other sites
Bucks 31 #37 Posted July 14, 2022 On 6/12/2022 at 6:55 PM, ebinmaine said: Those carbs can be rebuilt. Carefully and thoroughly. Remove the fuel bowl and check for obvious immediate blockages. I highly recommend using an OE carb if at all possible. Share this post Link to post Share on other sites
Bucks 31 #38 Posted August 3, 2022 agree. wound up removing carb & soaked in fresh gas with a strong dose of sea foam. 3 days with bowl taken off.re installed running great. THANKS ! 1 Share this post Link to post Share on other sites
ebinmaine 67,484 #39 Posted August 3, 2022 28 minutes ago, Bucks said: agree. wound up removing carb & soaked in fresh gas with a strong dose of sea foam. 3 days with bowl taken off.re installed running great. THANKS ! Excellent! Share this post Link to post Share on other sites
