Spottedeventer
Tiller for 314-8
Spottedeventer
Im looking to find a tiller for my dads old 314-8 which I dearly love. I found this toro tiller which is brand new but am unsure if it would work. Any assistance would be greatly appreciated
gwest_ca
Welcome to the forum.
This Troy built model may work but would require a ton of modifications.
For plug and play you need one of these
1983-1985 tiller model 07-36TL02
Uses tiller hitch 105543
Rear axle hitch mounts under rear axle
First belt guard on front idler assembly to be retained by bolts to a welded-on bracket
[Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1986-1989 tiller model 07-36TL03
1990-1991 tiller model 07-36TL04
[Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1992 tiller model 07-36TL05
1993-2001 2003-2007 tiller model 79370
There are older models that could fit with slight modifications
Ed Kennell
:text-welcomeconfetti: to the:rs:
roadapples
:WRS:
