c-series don
Donated my antique road grader
8ntruck
Looks like you found a good home for it.  As a bonus, you still get to play, rather, work with it from time to time.
  • Like 6
Pullstart
Wow Don, great work!  Is there a dual on the left side too, just no room on the trailer?
wallfish
Win Win
It's great that people will get to see that beautiful machine in action.
  • Like 7
c-series don
@Pullstart, yes dual wheels both sides. It’s an Oliver 2-44 with a McCormick-Dering grader unit. I’ve seen similar ones, but not the same one. I do know that it was sold by the same dealer that was the local Wheel Horse dealer, Rolle Bros. Even with the wheel lean in the front, you still need a football field to turn around!! It’s really more of a maintainer than a grader, but it does work well!
  • Excellent 2
Jeff-C175
3 hours ago, c-series don said:
donated
And, you should get a nice tax deduction for that too!  Hope they are a 501c !  So, it's a win, win, win !
ebinmaine
4 hours ago, c-series don said:
For my donation I will receive a lifetime membership and I’ll go run the grader to grade the track when they do the pulling
Excellent!!!
Daddy Don
You will always be the man of the hour. Great deal you did
oliver2-44
10 hours ago, c-series don said:
8 hours ago, c-series don said:
@Pullstart It’s an Oliver 2-44 with a McCormick-Dering grader unit. I’ve seen similar ones, but not the same one. I do know that it was sold by the same dealer that was the local Wheel Horse dealer, Rolle Bros. Even with the wheel lean in the front, you still need a football field to turn around!! It’s really more of a maintainer than a grader, but it does work well!
Don that is so cool. I have a White 2-44 loader/backhoe tractor. That I suspect is the same chassis as your grader. Mine is a Oliver -turned White Super 550 with an industrial front end and it originally had a forward/reverse shuttle transmission. The shuttle transmission was shot so I swapped in a farm tractor 6 speed transmission. Does your grader have the shuttle transmission?
c-series don
@oliver2-44 It does not have the shuttle shift transmission, it has a transmission with a high and low range, and all the gears on one shifter. I guess you could call it a six speed?
