tntatro 181 #26 Posted May 25, 2022 1 hour ago, stevasaurus said: Those bearings are WH #7207 (2) 3/8" ID. I do not know the height, but if it is 1/2" height the bearing would be KOYO or Torrington B-0608. Measure the height and inside diameter and put it here...I can tell you the bearings to get. Here is how KOYO and Torrington size their bearings..."B" = through bearing. The inside diameter and the height are in 16" , with the ID 1st and the height 2nd. So we have "B" with 3/8" ID which is 6/16". If the height is 1/2" that = 08/16". So your bearing is B-0608. If the height is 5/8"...it would be B-0610. Understand?? Thanks, I had some good used ones from a previous rebuild. The only new bearings are in the splined pinion gear. I didn't realize how durable those needle bearings are until I had to remove some from inside a shaft. 1 Share this post Link to post Share on other sites
