shipo 8 #1 Posted May 14, 2022 hello i am looking for help my 520 will not atay going forward and reverse is very very slow. is there a way to adjust and fix. if so how? 1 Share this post Link to post Share on other sites
kpinnc 13,667 #2 Posted May 14, 2022 Unfortunately there were too many different motion control versions for any of us to help you without either model numbers or pictures. 1 Share this post Link to post Share on other sites
lynnmor 7,554 #3 Posted May 14, 2022 Under the seat there is an access hole where you will find the cam plate. There is a friction adjustment nut that you will turn down a bit till the motion lever has some resistance to movement, adjust till it stays in place while operating. The cam follower that rides in that groove may be worn or out of adjustment causing the slow reverse, keep in mind that reverse is a bit slower than forward. Also, that friction area has washers that are not to be lubricated. Get things cleaned up and adjusted, then report back with results. 2 Share this post Link to post Share on other sites
rmaynard 15,908 #4 Posted May 14, 2022 Generally, if it's moving too slow, and motion control won't stay put, it's a problem in the linkage and/or cam plate (depending on model). As was said earlier, a little more info on year and the ID number would be helpful. 1 Share this post Link to post Share on other sites
Ed Kennell 40,415 #5 Posted May 14, 2022 to the Go to our manuals section and download your tractors manual. It will contain the info you need to adjust the motion control. If you have trouble finding the manual, post your tractors model number and we can post a link to your manual. 1 Share this post Link to post Share on other sites
shipo 8 #6 Posted May 14, 2022 ok yall sorry for the late reply just got outside. dont mind the pto pully off had a leak from crank seal waiting for replacement to arrive 3 Share this post Link to post Share on other sites
rmaynard 15,908 #8 Posted May 14, 2022 Look at the image below. Areas in red circles are places where slop can occur. These areas need to be tight and not producing a lot of unnecessary movement. This is an important step in making the motion control work correctly. The next image is of what you see under the seat. Again, make sure all connections are tight and not producing slop in the movement. The nut and washer circled control the "drag" on the motion control cam. They should not be lubricated, and tightened just enough to prevent the whole motion control linkage from moving on it's own. Adjustments to this cam is covered in the owners manual. 2 1 Share this post Link to post Share on other sites
shipo 8 #9 Posted May 14, 2022 you guys are awesome i will try some adjustments once i get the seal in today 2 Share this post Link to post Share on other sites
lynnmor 7,554 #10 Posted May 14, 2022 11 minutes ago, rmaynard said: Look at the image below. Areas in red circles are places where slop can occur. These areas need to be tight and not producing a lot of unnecessary movement. This is an important step in making the motion control work correctly. I have had the pin #65 work loose or fall out, just another place to look. 2 Share this post Link to post Share on other sites
peter lena 9,075 #11 Posted May 14, 2022 @shipo , even though not called for , https://www.amazon.com/Super-Lube-51004-Synthetic-Viscosity/dp/B000UKUHXK/ref=asc_df_B000UKUHXK?tag=bingshoppinga- makes those dry worn areas , work easier . while not trying to start a war , don't hesitate to add to a rusty , dragging spot , also a very good , throttle and choke cable lubricant . just an idea , pete 1 Share this post Link to post Share on other sites
roadapples 6,983 #12 Posted May 14, 2022 slow reverse, are you pushing the handle down before pulling it back? 1 Share this post Link to post Share on other sites
953 nut 57,768 #13 Posted May 14, 2022 If your hydro isn't moving well forward or back take a look under the tunnel cover between your legs, Squirrels, mice or chipmunks will drag all sorts of stuff in there to build a nest and make it their winter home. That can prevent the linkage from moving as far as it should. 4 Share this post Link to post Share on other sites
shipo 8 #14 Posted May 15, 2022 ok sorry for late responses. i got it adjusted up under the seat and foward stays up and reverse works great!. but its a bit jumpy now. 1 1 Share this post Link to post Share on other sites
rmaynard 15,908 #15 Posted May 15, 2022 8 minutes ago, shipo said: ok sorry for late responses. i got it adjusted up under the seat and foward stays up and reverse works great!. but its a bit jumpy now. My 416-H was jumpy. I fixed it by installing a "Matt's Foot Pedal" option. Not sure if he still makes them, but since installing, the whole motion control thing is 100% better. 2 Share this post Link to post Share on other sites
lynnmor 7,554 #16 Posted May 15, 2022 3 hours ago, shipo said: its a bit jumpy now. Sounds like you have a good strong hydro, they can be "jumpy" if the motion lever isn't moved smoothly. You might want to revisit the adjustment nut under the seat, if some small adjustments still result in jerky movement, then take it apart, sand the surfaces, clean well and reassemble. I use a bit of grease or oil on all of the moving parts except the friction washers. 3 Share this post Link to post Share on other sites
shipo 8 #17 Posted May 15, 2022 i believe i will waiting on filters deck bearings and blades to get here. then get it out on the 1st mow and see if anymore adjustment needs to be made 1 Share this post Link to post Share on other sites
Horse Newbie 7,195 #18 Posted May 15, 2022 (edited) TO !!!! You will find all the help you need here ! You have discovered the Worlds Best Wheel Horse Forum ! I like the way you dig into a tractor ! I have a 1994 520H too ! Edited May 15, 2022 by Horse Newbie 2 1 Share this post Link to post Share on other sites
peter lena 9,075 #19 Posted May 16, 2022 @lynnmor like your emphasis on the detailing and small adjustments on that unit. there is typically nothing that I have encountered on a horse related issue that could not use help . linkages are staring at you in a neglected / rusty state . do you have to go to a book to be instructed on obvious issues ? that super lube oil , that I refer to is terrific in those areas . also on neglected throttle and choke cables . pete Share this post Link to post Share on other sites
lynnmor 7,554 #20 Posted May 16, 2022 1 minute ago, peter lena said: @lynnmor linkages are staring at you in a neglected / rusty state . do you have to go to a book to be instructed on obvious issues ? The "book" has little to say about maintaining the linkage. It comes down to common sense that metal to metal contact points should have some kind of lubrication. Once a year I pull the seat, fender, console covers and fuel tank to clean it out and lube all moving joints. The amount of debris that collects in there is unbelievable and rust will start if it stays moist. 4 Share this post Link to post Share on other sites
Fishroe 261 #21 Posted May 24, 2022 On 5/14/2022 at 8:44 AM, rmaynard said: Look at the image below. Areas in red circles are places where slop can occur. These areas need to be tight and not producing a lot of unnecessary movement. This is an important step in making the motion control work correctly. The next image is of what you see under the seat. Again, make sure all connections are tight and not producing slop in the movement. The nut and washer circled control the "drag" on the motion control cam. They should not be lubricated, and tightened just enough to prevent the whole motion control linkage from moving on it's own. Adjustments to this cam is covered in the owners manual. i lubed all that stuff on the cam plate. Didn’t know I wasn’t suppose to ill have to clean it off my motion control lever is hard to find the neutral point. Maybe getting the grease off of it and snugging the nut just a tad might help it what do Yal think 1 Share this post Link to post Share on other sites
peter lena 9,075 #22 Posted May 25, 2022 @Fishroe thats easy , local hard ware store pull out drawer section , with Teflon washers or similar synthetic , says no lubrication , but if you need to , super lube synthetic , oil or spray . verify all the linkage points are moving without hang-up . often related connections are adding drag or out of adjustment , looks like an interesting job , pete Share this post Link to post Share on other sites
lynnmor 7,554 #23 Posted May 25, 2022 35 minutes ago, Fishroe said: i lubed all that stuff on the cam plate. Didn’t know I wasn’t suppose to ill have to clean it off my motion control lever is hard to find the neutral point. Maybe getting the grease off of it and snugging the nut just a tad might help it what do Yal think Notice that there are two #18 washers, one on each side of the cam plate. Those washers can wear in a way that they are no longer flat, so you might want to remove them and either flip over or sand them flat. While apart, clean the area well with parts cleaner. Adjustments for neutral are on page 13 of this manual. 1 Share this post Link to post Share on other sites
Handy Don 13,339 #24 Posted May 25, 2022 Supporting both @lynnmor and @Fishroe--getting the slop out of the linkages, to the extent you can, makes it a LOT easier to follow the neutral-setting procedure, Share this post Link to post Share on other sites
Bill D 2,083 #25 Posted May 25, 2022 1 hour ago, Handy Don said: Supporting both @lynnmor and @Fishroe--getting the slop out of the linkages, to the extent you can, makes it a LOT easier to follow the neutral-setting procedure, Does anyone have a copy of the neutral setting procedure? Thanks. 1 Share this post Link to post Share on other sites
