ebinmaine 69,707 #1 Posted May 13, 2022 I've had this Mckissick chipper for a bit and I've never been able to get the belt lined up quite right. It seems to want to grind one side off of the belt. The guy I bought this unit from had it mounted on the front of a Green thing. One of our members, awesome as usual, was nice enough to send me a front frame mounting bracket. This bracket appears to be semi-universal, so to speak. It's wider than a standard Wheelhorse frame by just exactly one inch. I tried equalizing it with two half inch spacers and then I moved it over so I had one inch all on one side. Recently I've discovered that the bolts holding the bracket half mounted to the actual chipper were corroded and loose so I'll be fixing that this weekend. I've tried using a 4-ft T-square but still can't quite get it right. What am I missing? Are there any tips and tricks to getting the pulleys straight to one another? Also, how much tension should I have on this belt.? It has a pretty long open space. 84 inch total length. 1 Share this post Link to post Share on other sites
peter lena 8,970 #2 Posted May 13, 2022 @ebinmaine , just snoopin around came across this ,https://www.bing.com/images/search?q=mckissick+chipper+hook+up+to+wheel+horse+tractor&qpvt=mckissick+chipper+hook+up+to+wheel+horse+tractor&form=IGRE&first=1&tsc=ImageHoverTitle , maybe some ideas ? pete 3 1 Share this post Link to post Share on other sites
JoeM 7,885 #3 Posted May 13, 2022 A piece of mason string for alignment. 84 inch can be forgiving. I would say to use a spring loaded pivot belt take up with that chipper on the return belt. lots of shock loading. something similar to a snow blower set up. An inch of belt deflection on that span. 2 Share this post Link to post Share on other sites
oliver2-44 10,074 #4 Posted May 13, 2022 16 minutes ago, JoeM said: A piece of mason string for alignment. 84 inch can be forgiving. I would say to use a spring loaded pivot belt take up with that chipper on the return belt. lots of shock loading. something similar to a snow blower set up. An inch of belt deflection on that span. Good advice! Check both pulleys to be running true, not slightly bent. your 4 foot t square is certainly a good tool to use. With it check that the chipper pulley is square with the tractor pulley by making sure its touching both sides of the tractor pulley and both sides of the chipper pulley 2 Share this post Link to post Share on other sites
peter lena 8,970 #5 Posted May 13, 2022 @Joe M @oliver2-44, agree with the initial set up check over , also an operational check over for function and detailing helps out . any thing that not follow easily , will be a glairing point to correct .would have an aerosol lubricant can and extension to make the rust run out on hang up areas . had a similar gravely set up that was solid rust , greasy, pete 1 Share this post Link to post Share on other sites
ebinmaine 69,707 #6 Posted May 13, 2022 2 hours ago, peter lena said: maybe some ideas Excellent. Thanks for that. I saved a couple pics. 2 hours ago, JoeM said: A piece of mason string for alignment. 84 inch can be forgiving. I would say to use a spring loaded pivot belt take up with that chipper on the return belt. lots of shock loading. something similar to a snow blower set up. An inch of belt deflection on that span. Like that spring loaded idea. I have some actual mason string around. I'll try that. An inch of deflection? So that's a pretty tight belt at that point eh? 2 hours ago, oliver2-44 said: 4 foot t square is certainly a good tool to use. With it check that the chipper pulley is square with the tractor pulley by making sure its touching both sides of the tractor pulley and both sides of the chipper pulley Issue with the T square is that the chipper body is in the way. I can get it "close". Ish.... I'll try to see about using the string. Both pulleys seem straight enough ok but the tractor PTO pulley is tough to line up on because of the shape of the PTO being a "bell". 🔔 2 Share this post Link to post Share on other sites
JPWH 6,158 #7 Posted May 13, 2022 @ebinmaineI found that using a small rope centered in the pulley grooves in place of the belt will give an accurate reference for alignment. Jay 3 1 Share this post Link to post Share on other sites
ebinmaine 69,707 #8 Posted May 13, 2022 1 minute ago, JPWH said: @ebinmaineI found that using a small rope centered in the pulley grooves in place of the belt will give an accurate reference for alignment. Jay Clothesline? Or do you have a different recommendation? 1 Share this post Link to post Share on other sites
Handy Don 13,080 #9 Posted May 13, 2022 And maybe some flex in the mounting when the chipper takes a big bite and there's a lot of torque? 3 Share this post Link to post Share on other sites
cafoose 3,360 #10 Posted May 13, 2022 Maybe rig up an alignment tool something like this? 3 Share this post Link to post Share on other sites
JPWH 6,158 #11 Posted May 13, 2022 1 minute ago, ebinmaine said: Clothesline? Or do you have a different recommendation? That may work. Something like parachute cord or mule tape is what I use. 2 Share this post Link to post Share on other sites
ebinmaine 69,707 #12 Posted May 13, 2022 1 minute ago, JPWH said: parachute cord Fair amount of that around. 3 Share this post Link to post Share on other sites
ebinmaine 69,707 #13 Posted May 13, 2022 5 minutes ago, Handy Don said: And maybe some flex in the mounting when the chipper takes a big bite and there's a lot of torque? That's built in there. Interesting you'd bring that up. The hanger that holds these things in place is two pins kind of like the springs on a snow plow. There's already some movement in there. 2 Share this post Link to post Share on other sites
JPWH 6,158 #14 Posted May 13, 2022 The pulleys are not always the same thickness that's why I like to align the centers and not the edge. 3 2 Share this post Link to post Share on other sites
ebinmaine 69,707 #15 Posted May 13, 2022 Just now, JPWH said: The pulleys are not always the same thickness that's why I like to align the centers and not the edge. I can see the logic in that 2 Share this post Link to post Share on other sites
ebinmaine 69,707 #16 Posted May 13, 2022 5 minutes ago, cafoose said: alignment tool I love the idea of this but the tractor end is the PTO which is bell-shaped 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #17 Posted May 13, 2022 Eric... which one of these are we talking about...? Just offset? Don 3 Share this post Link to post Share on other sites
ebinmaine 69,707 #18 Posted May 13, 2022 2 minutes ago, Snoopy11 said: Eric... which one of these are we talking about...? Just offset? Don Most likely offset but there could be a touch of angle in there and I just can't see it without proper tools 2 Share this post Link to post Share on other sites
Snoopy11 5,717 #19 Posted May 13, 2022 I can't remember for the life of me... but I talked to the V-belt guys (actual professional company) at one time about this very issue. They told me that there is a certain amount of angle that is tolerable in v-belt applications. Also... using a bigger width belt (if possible), or rubber style belt may help. Don 2 Share this post Link to post Share on other sites
cafoose 3,360 #20 Posted May 13, 2022 5 minutes ago, ebinmaine said: I love the idea of this but the tractor end is the PTO which is bell-shaped Maybe instead of square blocks on the pulleys you can use rods of equal length? Think of the square blocks as two rods coming from the flat steel. Maybe drill holes in the flat steel and use all thread with nuts on either side of the flat steel so they can be adjusted? That should clear the PTO bell and if necessary the pulley hub on the chipper. 3 Share this post Link to post Share on other sites
ebinmaine 69,707 #21 Posted May 13, 2022 35 minutes ago, Snoopy11 said: rubber style belt You bring up an important point. I'm using a cloth belt like an 8-speed Drive belt. @Oldskool Mike reminded me that mowers use rubber belts. I'm thinking now that maybe this application should be a rubber belt... NOT a cloth sided belt?? 5 Share this post Link to post Share on other sites
squonk 41,930 #22 Posted May 13, 2022 Rubber and cogged. Any pic of this issue Eric? 2 Share this post Link to post Share on other sites
Ed Kennell 39,733 #23 Posted May 13, 2022 4 hours ago, JoeM said: 84 inch can be forgiving. I would say to use a spring loaded pivot belt take up with that chipper on the return belt. lots of shock loading. something similar to a snow blower set up. Alignment should not be a problem on an 84" belt. The shock loadig can be. I had to make a two pulley snow blower tensioner with a strong spring for the front tiller. The tenioner is necessary to keep the belt in the groove with these high shock load devices. 3 2 Share this post Link to post Share on other sites
ebinmaine 69,707 #24 Posted May 13, 2022 15 minutes ago, squonk said: Rubber and cogged. Any pic of this issue Eric? No sir. Really couldn't get a pic that made sense. The belt I had that wore right off one side is long gone. 10 minutes ago, Ed Kennell said: Alignment should not be a problem on an 84" belt. The shock loadig can be. I had to make a two pulley snow blower tensioner with a strong spring for the front tiller. The tensioner is necessary to keep the belt in the groove with these high shock load devices. I'll take a look at a snowblower chassis I have on hand. Might have usable spring loaded pulley. Sounds like I need to really tighten right up on the belt? 3 Share this post Link to post Share on other sites
sjoemie himself 3,072 #25 Posted May 13, 2022 I would also recommend a tensioner. My WH with sweeper also has a pretty long belt on it, also has a tensioner. Like some guys said before, misalignment might not be your biggest problem. 2 Share this post Link to post Share on other sites
