Wheelhorse#1 1,890 #1 Posted May 12, 2022 Trying to mock up to add the tunnels under the deck,they were missing and it definitely doesn’t cut well with out them. Trying to figure out a way to fasten them ,no welder here.What gage steel would be good to use that would be still flexible enough to bend yet strong enough ? Anyone have any ideas or experience with this? thx 2 Share this post Link to post Share on other sites
daveoman1966 3,881 #2 Posted May 12, 2022 Looks good. If it was me doin' this, I'd use GALVANIZED sheetmetal...as from fixing a rusted out car fender. Attached with 3/16" pop-rivets. The galv will last for years and years to come, easy to work with, cheap to buy too. If you EVER have to rep;ace, also easy to do. Instead of welding, when you make the 'tunnels', make them an inch or so wider than needed, then fold over the extra 1", cutting every few inches to create a 'TAB' that you can drill thru to attach with pop rivets. 4 1 Share this post Link to post Share on other sites
pacer 3,177 #3 Posted May 12, 2022 Your mock up looks great! and @daveoman1966 suggestion is very good and should be doable with common shop tools. Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #4 Posted May 12, 2022 (edited) Thanks all .Excellent idea daveoman1966 I been needing a pop rivet gun anyway.Should be easy enough. Ill post up when completed . Off to harbor fraud and get material. Edited May 12, 2022 by Wheelhorse#1 Share this post Link to post Share on other sites
Handy Don 15,179 #5 Posted May 12, 2022 I heartily suggest NOT going cheap on the pop rivet tool. Get one that handles multiple diameters of rivet shaft and has excellent leverage. The part that fails on these tools is where the tool grabs the stem of the rivet. Also, be sure to use stainless steel pop rivets (aluminum will not play well with galvanized metal and regular steel will rust quickly). It looks like someone with good welding skills already did some very clean repairs on that deck. 2 Share this post Link to post Share on other sites
peter lena 9,556 #6 Posted May 12, 2022 @Wheelhorse#1 what's the cutting issue ? have 3 of those r/d decks with no baffling at all ,cutting is always good with zero trailing , cut at highest setting , sharp blades . alternate cutting angles always changing pattern. another thing is your smooth clean underside , been doing that same type of oil soaking to stop rot for years . just curious , pete Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #7 Posted May 12, 2022 Well the repair will have to wait. Im not about to pay $25 bucks for a piece of 8x25 sheet of galvanized sheet metal .One store had nothing in stock.Days of cheap are gone. Share this post Link to post Share on other sites
Handy Don 15,179 #8 Posted May 12, 2022 2 minutes ago, Wheelhorse#1 said: Well the repair will have to wait. Hope your are not holding your breath..... Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #9 Posted May 12, 2022 1 hour ago, peter lena said: @Wheelhorse#1 what's the cutting issue ? have 3 of those r/d decks with no baffling at all ,cutting is always good with zero trailing , cut at highest setting , sharp blades . alternate cutting angles always changing pattern. another thing is your smooth clean underside , been doing that same type of oil soaking to stop rot for years . just curious , pete Yes Pete.Those tunnels or baffles give lift.Lifting the grass up for a more even cut.Its probably good enough but I can can tell and it bothers me. 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #10 Posted May 12, 2022 Just now, Handy Don said: Hope your are not holding your breath..... No sir.ill get scraps from work.thanks Biden ! 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #11 Posted May 12, 2022 (edited) 3 hours ago, Handy Don said: I heartily suggest NOT going cheap on the pop rivet tool. Get one that handles multiple diameters of rivet shaft and has excellent leverage. The part that fails on these tools is where the tool grabs the stem of the rivet. Also, be sure to use stainless steel pop rivets (aluminum will not play well with galvanized metal and regular steel will rust quickly). It looks like someone with good welding skills already did some very clean repairs on that deck. Don I bought the top of the line at harbor fraud, 25 bucks worth.well it cost more so it should be better...right ? Yes the PO did lots of welding and didn't scrimp on steel.It probably weights more than a 1965 four door Buick. Edited May 12, 2022 by Wheelhorse#1 2 Share this post Link to post Share on other sites
roadapples 6,985 #12 Posted May 12, 2022 Since you've already got those pieces made I would use them. They should last for years. And being pop riveted they will be easy to replace when you get galvanized or stainless... 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #13 Posted May 13, 2022 3 hours ago, roadapples said: pieces made I would use them. They should last for years Corrugated cardboard? 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #14 Posted May 13, 2022 5 minutes ago, Jeff-C175 said: Corrugated cardboard? Yes.Just a mock up to make sure I had placement right. 1 Share this post Link to post Share on other sites
roadapples 6,985 #15 Posted May 13, 2022 11 minutes ago, Jeff-C175 said: Corrugated cardboard? Oops, hard to see on this little phone 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #16 Posted May 13, 2022 11 minutes ago, roadapples said: Oops, hard to see on this little phone Happens to me all the time! 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #17 Posted May 13, 2022 (edited) 33 minutes ago, Wheelhorse#1 said: Yes.Just a mock up to make sure I had placement right. I've got some steel, galvanized, that would be suitable, but the road trip to pick it up would be more expensive than the free material! Edited May 13, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #18 Posted May 13, 2022 1 hour ago, Jeff-C175 said: I've got some steel, galvanized, that would be suitable, but the road trip to pick it up would be more expensive than the free material! Thanks for the offer.Jeff.Its the thought that count. 1 Share this post Link to post Share on other sites
