Fishroe 261 #1 Posted May 10, 2022 Just wondering do Yal put grease on the sector gear. I think it helps but everything sticks to it Share this post Link to post Share on other sites
8ntruck 7,254 #2 Posted May 10, 2022 I've been wondering that, myself. I was thinking of something like DrySlide or powdered graphite? Share this post Link to post Share on other sites
Ed Kennell 39,725 #3 Posted May 10, 2022 I like grease. Where you at greasy Pete? @peter lena 2 1 Share this post Link to post Share on other sites
953 nut 56,717 #4 Posted May 10, 2022 I did that a couple of times and found that it attracted dirt and didn't improve steering effort. You should grease the support at the fitting . The biggest thing you can do to improve your steering is to place added shim washers (parts 30 and 31) between the steening support (part 22) and the cotter key on the steering shaft to draw the steering gear (25) closer to the fan gear (33). If there is too much slop there the gear teeth will tend to bind. The shims go behind the steering support, 4 Share this post Link to post Share on other sites
peter lena 8,968 #5 Posted May 10, 2022 @Fishroe think its a trade off , lubrication is vital to its function , yet its trapped in the grass debris area . you would have to regularly clean that area out to help things out . for me the lubricant wins , regularly check out mechanical function of everything @Ed Kennell i,m with you and others on grease . especially in the fan gear cavities, can easily wipe down excess . like to lubricate that area , while its hanging free . thats when its most effective . always greasy , pete 2 Share this post Link to post Share on other sites
Fishroe 261 #6 Posted May 10, 2022 Thanks guys very helpful I’ve always greased them but probably not as often as I should 1 1 Share this post Link to post Share on other sites
balconio 606 #7 Posted May 10, 2022 i gob on a finger full every time i hit the frontend zerks with grease Share this post Link to post Share on other sites
