Brockport Bill
c165 which tranny
Brockport Bill
would someone be able to please confirm the transmission for c165 --- #01-16kS01-5576 -- i thought the S was an 8 but apprently not? i checked the manuals here but still not certain if it lists as Sunstrand or Eaton? thanks
stevasaurus
Appears to be a Sundstrand 90-1173...1980.
stevasaurus
Looking at the list farther, it appears that "no letter" after the "K" would be an 8 speed.  So...assuming the "S" is Sunstrand., the "E" is for Eaton.  A "P" would be Peerless.
   The "K" might be for Kohler??  "B" is for Briggs, "O" is for Onan, "E" is for Electric.
Brockport Bill
clarification -- the ID number is an 8 not an S .......#01-16k801-5576 ....... its a Kohler 16 single with 8 speed ...with a tag on tranny.... Uni Drive #2988185
Brockport Bill
trying to determine what oil and what quantity? thanks
Brockport Bill
i think i found for the C165 and this model tractor  number #01-16k801-5576....that it is trans # 103916 - - is that correct?
Brockport Bill
i am also seeing it showing as tranny model 5086 ?????????????
Bill D
Oil for the 8 speed transmission will be 80W-90.  Available at any auto parts store for about $10 a quart.  The transmission holds two quarts.
gwest_ca
5086 has 1" diameter axles.
C-165 will have 1-1/8" axles.
Brockport Bill
thanks - - yes, i just measured the axle - 1 1/8 inches
stevasaurus
Here is the deal.  We have a typo mistake somewhere.  The 01-16K801 is a 1980 C-165.  The transmissions are in question.  One source shows 103918, the other shows the 103916.  After looking at a bunch IPL's, I am going to call it #103916...an 8 speed, 8 pinion with 1 1/8" axles.  :occasion-xmas:  Use 90wt gear oil, 2 qts in a new transmission.
After looking some more...I find the #103918 is the transmission that is used in the 8 speed Electric models...E-141
gwest_ca
The103918 transmission was used on the E-141 electric tractors
