Brockport Bill 1,825 #1 Posted May 8, 2022 would someone be able to please confirm the transmission for c165 --- #01-16kS01-5576 -- i thought the S was an 8 but apprently not? i checked the manuals here but still not certain if it lists as Sunstrand or Eaton? thanks Share this post Link to post Share on other sites
stevasaurus 23,079 #2 Posted May 8, 2022 Appears to be a Sundstrand 90-1173...1980. Share this post Link to post Share on other sites
stevasaurus 23,079 #3 Posted May 8, 2022 Looking at the list farther, it appears that "no letter" after the "K" would be an 8 speed. So...assuming the "S" is Sunstrand., the "E" is for Eaton. A "P" would be Peerless. The "K" might be for Kohler?? "B" is for Briggs, "O" is for Onan, "E" is for Electric. 2 Share this post Link to post Share on other sites
Brockport Bill 1,825 #4 Posted May 8, 2022 clarification -- the ID number is an 8 not an S .......#01-16k801-5576 ....... its a Kohler 16 single with 8 speed ...with a tag on tranny.... Uni Drive #2988185 Share this post Link to post Share on other sites
Brockport Bill 1,825 #5 Posted May 8, 2022 trying to determine what oil and what quantity? thanks Share this post Link to post Share on other sites
Brockport Bill 1,825 #6 Posted May 8, 2022 i think i found for the C165 and this model tractor number #01-16k801-5576....that it is trans # 103916 - - is that correct? Share this post Link to post Share on other sites
Brockport Bill 1,825 #7 Posted May 9, 2022 i am also seeing it showing as tranny model 5086 ????????????? Share this post Link to post Share on other sites
Bill D 2,097 #8 Posted May 9, 2022 Oil for the 8 speed transmission will be 80W-90. Available at any auto parts store for about $10 a quart. The transmission holds two quarts. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,252 #9 Posted May 9, 2022 46 minutes ago, Brockport Bill said: i am also seeing it showing as tranny model 5086 ????????????? 5086 has 1" diameter axles. C-165 will have 1-1/8" axles. 1 Share this post Link to post Share on other sites
Brockport Bill 1,825 #10 Posted May 9, 2022 thanks - - yes, i just measured the axle - 1 1/8 inches Share this post Link to post Share on other sites
stevasaurus 23,079 #11 Posted May 9, 2022 Here is the deal. We have a typo mistake somewhere. The 01-16K801 is a 1980 C-165. The transmissions are in question. One source shows 103918, the other shows the 103916. After looking at a bunch IPL's, I am going to call it #103916...an 8 speed, 8 pinion with 1 1/8" axles. Use 90wt gear oil, 2 qts in a new transmission. After looking some more...I find the #103918 is the transmission that is used in the 8 speed Electric models...E-141 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,252 #12 Posted May 9, 2022 The103918 transmission was used on the E-141 electric tractors 1 Share this post Link to post Share on other sites
