redrider55 2 #1 Posted May 8, 2022 i have a b80 that the fuel pump lever doesnt touch the cam. seems the cam is shifted away from the pto side. ive tried a new fuel pump, just wonering if there is anything to look for before tearing down. it does run on gravity fed but not real smooth. should the lobe for the fuel pump be centered exactly in the fuel pump opening? Share this post Link to post Share on other sites
pfrederi 18,188 #2 Posted May 8, 2022 (edited) small block Kohlers K181 fuel pumps have an offset in the pump arm. if you are trying to use a big block pump it will not work Edited May 8, 2022 by pfrederi 3 Share this post Link to post Share on other sites
pfrederi 18,188 #3 Posted May 8, 2022 K181 pump on the left big block (10hp and up) right Welcome 2 Share this post Link to post Share on other sites
Pullstart 63,551 #4 Posted May 8, 2022 to another Michigander! There are some fuel pumps that are vacuum operated too. If the diaphragm is good, they work quite well too. 1 Share this post Link to post Share on other sites
redrider55 2 #5 Posted May 8, 2022 14 minutes ago, pfrederi said: small block Kohlers K181 fuel pumps have an offset in the pump arm. if you are trying to use a big block pump it will not work thanks for the info this has to be it! Share this post Link to post Share on other sites
redrider55 2 #6 Posted May 8, 2022 9 minutes ago, Pullstart said: to another Michigander! There are some fuel pumps that are vacuum operated too. If the diaphragm is good, they work quite well too. i did see that too, i rescued this thing from the scrap crusher and it didnt have a pump on it. it had an old one laying on it that was the strait style so i ordered another of those not knowing. thank a lot for the great inflo 2 Share this post Link to post Share on other sites
