Horse Newbie 7,184 #26 Posted May 12, 2022 (edited) @Fishroe Check at Wheel Horse Parts and More… Lowell sells the o rings for the lift valve. I think the correct name for it is a “spool valve”. You can find an exploded view of the parts in our files if you go there and look for the manuals for your year and model tractor. There is an acorn nut on the spool valve somewhere… don’t remove that nut. It is some kind of adjustment nut, and some instructions some where on the hydraulic system says “DO NOT ADJUST”, or something like that. When I refreshed my ‘94 520 H, I took that acorn nut off but did not turn the screw underneath it. If I recall correctly it was an Allen head screw. See if you can find my thread on refreshing the 520H… there is probably some useful info on that thread as I rebuilt my spool valve and my lift cylinder. Edited May 12, 2022 by Horse Newbie 1 Share this post Link to post Share on other sites
Horse Newbie 7,184 #27 Posted May 12, 2022 On 5/9/2022 at 3:10 PM, Fishroe said: Got the pin out. After taking the panel with the gauges off hopefully I found the problem The compression spring thingy attached to the lift lever was rusted pretty bad and sticking. The plunger in the, I guess that’s called the control valve, wasn’t going in and out like it should The other one on the motion lever was sticking some too 1st pic. I hope the control valve is not bad. I would guess that’s not made any longer grease fitting on the bottom of the steering shaft, I wouldn’t think they put that in like that from the factory See that acorn nut on the left side of the first pic ?… if you take it off, DO NOT ADJUST the Allen screw behind it unless you are a hydraulics expert, or an expert on the Eaton 1100. 1 Share this post Link to post Share on other sites
Horse Newbie 7,184 #28 Posted May 12, 2022 @Fishroe… I may have mislead you… I may not have done a thread on “refreshing the ‘94 520H… maybe you can search my content and find where I rebuilt my spool valve and lift cylinder… Sorry… 1 Share this post Link to post Share on other sites
Fishroe 261 #29 Posted May 12, 2022 10-4 on the acorn nut when my fuel valve gets here I will know whether it works or not Thanks 1 Share this post Link to post Share on other sites
Handy Don 13,141 #30 Posted May 13, 2022 17 hours ago, Horse Newbie said: There is an acorn nut on the spool valve somewhere… don’t remove that nut. It is some kind of adjustment nut, and some instructions some where on the hydraulic system says “DO NOT ADJUST”, or something like that. That screw under the nut adjusts the control valve's pressure relief mechanism. Messing with it could either make your lift useless or break your hydro's charge pump. Unless you have the proper equipment and a solid understanding of hydraulic systems, follow the manual's advice and DO NOT ADJUST. 1 Share this post Link to post Share on other sites
Fishroe 261 #31 Posted May 15, 2022 (edited) Good news and bad news put the new fuel valve in and fired her up lift lever hydraulics are working fine for now Cut engine off and put everything back together so I could drive it around and recheck oil level in trans. Backed out the garage and it started spitting and sputtering. Pulled it back in garage before it cut off. It’s puking gas out of the front of the carburetor. 😠😠😩😩. No problem rebuilding it. The problem will be finding parts its a walbro whg 79-2274. Can someone point me in the right direction for the parts needle, seat, gaskets, possibly a float. Hadn’t taken it off yet. Start fresh in the morning. If parts aren’t available I’ll have to go the Chinese route. Maybe I’ll get lucky and just find trash in the bowl keeping the needle from seating Edited May 15, 2022 by Fishroe 1 Share this post Link to post Share on other sites
Horse Newbie 7,184 #32 Posted May 17, 2022 I put a China carb on my 1994 520H, P220 Onan, and it’s running good… maybe I got lucky. Held on to the original carb though… 1 Share this post Link to post Share on other sites
Fishroe 261 #33 Posted May 20, 2022 (edited) Got it running cleaned carb, new needle, fuel line, filter, fuel valve, cleaned tank and another plastic fuel pump Edited May 20, 2022 by Fishroe 1 Share this post Link to post Share on other sites
Charlie Drannbauer 0 #34 Posted May 20, 2023 I've got a 314 Hydro that goes forward seemingly fine, but reverse is very sluggish. The guy I bought it from indicated that there is a "slide valve" that probably has worn or defective "O" rings allowing leakage" when shifting into reverse. Is there bar kit that contains the necessary parts to repair this issue? Also whatever instructions that may be available. Thanks, Charlie Share this post Link to post Share on other sites
953 nut 57,016 #35 Posted May 20, 2023 (edited) 11 hours ago, Charlie Drannbauer said: I've got a 314 Hydro that goes forward seemingly fine, but reverse is very sluggish. The guy I bought it from indicated that there is a "slide valve" that probably has worn or defective "O" rings allowing leakage" when shifting into reverse. Is there bar kit that contains the necessary parts to repair this issue? Also whatever instructions that may be available. Thanks, Charlie If you start a new thread under the transmission section you will a lot more answers that tagging on to an old thread. Click on this link to get started, https://www.wheelhorseforum.com/forum/49-transmissions-and-transaxles/ Include the model numbe of your tractor found under the left side under the seat. Edited May 20, 2023 by 953 nut Share this post Link to post Share on other sites
cleat 6,884 #36 Posted May 20, 2023 On 5/12/2022 at 5:39 PM, Horse Newbie said: I need a link to that hard-wired hour meter… That is my tractor. The bracket I just made from a scrap of stainless steel that I had lying around and the hour meter itself is a small panel mount unit that I believe I bought off of ebay. The OEM hour meter was removed so I could install a fuel gauge on the tractor from a 520 (it was not working properly anyways). Here it is being fitted prior to the machine being rebuilt. This is the fuel gauge and the tank with the sending unit. 2 1 Share this post Link to post Share on other sites
cleat 6,884 #37 Posted May 20, 2023 (edited) Duplicate post Edited May 20, 2023 by cleat Share this post Link to post Share on other sites
