Fishroe 261 #1 Posted May 7, 2022 (edited) Just bought it not running Replaced fuel pump. Motor runs great. 339 hrs Hour meter does work Trans goes forward and reverse but the other lever doesn’t seem to want to move Im lost. Never owned a hydro before Trans fluid was low, at the bottom of the safe line on dipstick. I put 10w-30 in. Looks like it might have a leak on the end of the hydraulic hose. Hard to tell with all the crud under there. got to clean it up. Big air bubbles in the funnel when filling. I put a quart in. Stopped to eat. Will check fluid level later Edited May 7, 2022 by Fishroe 1 Share this post Link to post Share on other sites
pfrederi 18,223 #2 Posted May 7, 2022 Other lever you mean the hydraulic lift??? You need to clean it up dump the fluid get fresh and new filter Wix 51410 2 Share this post Link to post Share on other sites
Fishroe 261 #3 Posted May 7, 2022 Yes hydraulic lift ive got the oil a new toro filter came with it 2 Share this post Link to post Share on other sites
pfrederi 18,223 #4 Posted May 7, 2022 Hydros are hard to fill. Run it for a couple minutes then check the level again. may be an air bubble. 1 Share this post Link to post Share on other sites
Fishroe 261 #5 Posted May 8, 2022 (edited) Changed oil and filter. It didn’t help i got the lift lever moving forward but not backward. Just the lever is moving not the cylinder. It was putting a little bit of a load on the engine. Actually made the belt squeal some what got the lever moving forward was spraying wd40 on a compression spring with a nut on top, right behind the battery. looks like the regulator on a well pump or air compressor. I don’t know whether some linkage is binding and needs lube or what, (Talk to me Pete!!) or the cylinder underneath is froze. I’ll do some more exploring tomorrow. I just wouldn’t think, with only 339 hours the cylinder would be bad, but I don’t know, don’t have any experience with these hydros. I’m wondering if I can unhook the cylinder and watch and see if the shaft that comes out of the trans that drives the cylinder is turning. Just a guessing game right now if someone can point me in the right direction I’m all ears Edited May 8, 2022 by Fishroe 1 Share this post Link to post Share on other sites
kpinnc 13,266 #6 Posted May 8, 2022 (edited) The lift valve uses o-rings on the shaft inside the valve body. They might be dried out and sticky. If so, they will likely start leaking. Given where the valve is, it's a good idea to replace the o-rings before putting the tractor to use. And degrease and clean that tranny. Remove the fender, and fuel tank and get those fins clean. Otherwise it will overheat and destroy the transmission. And congrats on the tractor. A 314-H is a very good machine! Edited May 8, 2022 by kpinnc 1 1 Share this post Link to post Share on other sites
Bill D 2,068 #7 Posted May 8, 2022 4 hours ago, Fishroe said: Changed oil and filter. It didn’t help i got the lift lever moving forward but not backward. Just the lever is moving not the cylinder. It was putting a little bit of a load on the engine. Actually made the belt squeal some what got the lever moving forward was spraying wd40 on a compression spring with a nut on top, right behind the battery. looks like the regulator on a well pump or air compressor. I don’t know whether some linkage is binding and needs lube or what, (Talk to me Pete!!) or the cylinder underneath is froze. I’ll do some more exploring tomorrow. I just wouldn’t think, with only 339 hours the cylinder would be bad, but I don’t know, don’t have any experience with these hydros. I’m wondering if I can unhook the cylinder and watch and see if the shaft that comes out of the trans that drives the cylinder is turning. Just a guessing game right now if someone can point me in the right direction I’m all ears Please post pictures of the areas of concern so we can help you better. Thanks 1 Share this post Link to post Share on other sites
Fishroe 261 #8 Posted May 8, 2022 I blew it off yesterday pretty good. I will take the fender and tank off. I would take it out of the garage, spray degreaser and pressure wash but weather here yesterday and today is 47 degrees,windy and drizzling rain most of yesterday and today. I’ll be 2 weeks behind on planting green beans and cucumbers Forward and reverse is very responsive The main concern is why the lift lever will not move to the down position pic of cylinder. Looks like it’s all the way out 1 Share this post Link to post Share on other sites
Fishroe 261 #9 Posted May 8, 2022 Cleaned it up fins weren’t bad at all That fitting don’t look right need some professional verification on that 1 Share this post Link to post Share on other sites
Fishroe 261 #10 Posted May 9, 2022 Saw a pic of cleats rebuild fitting looks the same 1 Share this post Link to post Share on other sites
squonk 42,056 #11 Posted May 9, 2022 I'm wondering if the rock shaft is all bound up causing the lift to load up the engine and not the lift cylinder. 1 Share this post Link to post Share on other sites
Handy Don 13,143 #12 Posted May 9, 2022 Normally, when the lift cylinder reaches end-of-travel or its load limit, the pressure relief at the control will open and the engine should never be taxed at all. If I'm reading your post correctly, @Fishroe you have problems at your control valve. A full overhaul seems indicated. 1 Share this post Link to post Share on other sites
squonk 42,056 #13 Posted May 9, 2022 Disconnect your lift cylinder from the white arm and see if that arm moves back and forth freely. I have seen these freeze up solid. 3 Share this post Link to post Share on other sites
Fishroe 261 #14 Posted May 9, 2022 I was going to take that side cover off yesterday when I was cleaning. The parking brake lock lever has a miniature roll pin in it. Does the pin have to come out or can you take the nut off and the shaft comes out with the cover. Already went through drilling out the pin in the steering shaft When I do disconnect the arm from the cylinder should I be able to push the cylinder in and out Wont be able to test it for a few days, ordered new fuel valve and bushing yesterday unless I hook up a gravity feed tank. I do have one 1 Share this post Link to post Share on other sites
Handy Don 13,143 #15 Posted May 9, 2022 That *$%#@ pin has to come out. A roll pin punch will help a lot and excellent support is mandatory (I took off the footrest and cut a 2x3" with a notched V that reached to the floor). 2 Share this post Link to post Share on other sites
Fishroe 261 #16 Posted May 9, 2022 (edited) Damm!t man!! time to get the blaster out. Maybe I’ll get lucky this time I wouldnt bet on it though 😩😩 Edited May 9, 2022 by Fishroe 1 Share this post Link to post Share on other sites
Fishroe 261 #17 Posted May 9, 2022 Anybody know what size the 933135 roll pin is can’t find anything on the web 1 Share this post Link to post Share on other sites
Handy Don 13,143 #18 Posted May 9, 2022 Don't think I've ever measured it! ⅛" if I were guessing. 1 Share this post Link to post Share on other sites
Fishroe 261 #19 Posted May 9, 2022 2 hours ago, Handy Don said: That *$%#@ pin has to come out. A roll pin punch will help a lot and excellent support is mandatory (I took off the footrest and cut a 2x3" with a notched V that reached to the floor). I will try that thanks Don 1 Share this post Link to post Share on other sites
Fishroe 261 #20 Posted May 9, 2022 Got the pin out. After taking the panel with the gauges off hopefully I found the problem The compression spring thingy attached to the lift lever was rusted pretty bad and sticking. The plunger in the, I guess that’s called the control valve, wasn’t going in and out like it should The other one on the motion lever was sticking some too 1st pic. I hope the control valve is not bad. I would guess that’s not made any longer grease fitting on the bottom of the steering shaft, I wouldn’t think they put that in like that from the factory 1 Share this post Link to post Share on other sites
Handy Don 13,143 #21 Posted May 9, 2022 (edited) If the piston goes in and out of the control valve smoothly (and is rust free) that's a good sign that the issue might be confined to the linkage. I'm still bothered that lift taxed the engine--that indicates that the pressure relief valve (built into the control valve on this model) is not functioning as it should. That zerk on the bottom of the steering block? Absolutely factory and probably the least used by many owners (it IS clearly marked in the owner's manual diagram). Wallowing at that block is the source of a lot of slopping steering. Edited May 9, 2022 by Handy Don 1 Share this post Link to post Share on other sites
Fishroe 261 #22 Posted May 9, 2022 Is the control valve available if needed 1 Share this post Link to post Share on other sites
Handy Don 13,143 #23 Posted May 9, 2022 Definitely available used from AtoZ and I think WH PartsandMore will refurb them. Both vendors vendors listed under Classified/Vendors at the top of this page. 1 Share this post Link to post Share on other sites
Fishroe 261 #24 Posted May 9, 2022 That’s good to know Thanks for your help 2 Share this post Link to post Share on other sites
Horse Newbie 7,184 #25 Posted May 12, 2022 On 5/9/2022 at 9:09 AM, squonk said: Disconnect your lift cylinder from the white arm and see if that arm moves back and forth freely. I have seen these freeze up solid. I need a link to that hard-wired hour meter… Share this post Link to post Share on other sites
