Michael Ragan 12 #1 Posted May 5, 2022 Help , I have all original Wheel Horse 1045 , I need to find out what size or brand of belt that fits the starter generator to the engine. It has the original Kohler 10 hp k241 engine I am pretty sure. Thank any help is appreciated Michael 1 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,251 #2 Posted May 5, 2022 Click on the picture in this link. Belts listed on the page that will come up. 2 Share this post Link to post Share on other sites
cschannuth 3,817 #3 Posted May 5, 2022 You can also take the original belt to any good auto parts store and they should be able to get you close. I usually buy the one I think I’m going to need and then purchase the larger size and the next smaller size and then take back the two that don’t fit. If there’s no belt at all you can use a thick piece of rope around both pulleys to get you in the ballpark as well. 1 Share this post Link to post Share on other sites
squonk 42,579 #4 Posted May 5, 2022 Mike, Napa / Gates 25-7345 Rubber edged cogged belt. Will get you right in the middle of the adjustment. Costs more than a 4L350 belt but it will grip better and run cooler. Notched design fits around smaller pullies easier. Belt Angle: 37 Deg Belt Construction: Notched Belt Material: Ethylene (EPDM) Brand: NAPA Cord Material: Polyester Cross Section Designation of Belt: HC41 Effective Length: 34.59 in Manufacturer: Gates Notched Belt: Yes Number of Strands: 1 Outside Circumference: 35.35 in SDS Required: No Top Width: .41 4 1 Share this post Link to post Share on other sites
ri702bill 8,993 #5 Posted May 5, 2022 There has been quite a bit of discussion as to S/G belts. Seems most folks prefer a belt with rubber, not a Kevlar wrap, on the sides - those are doing the gripping and driving ... @squonk beat me to it. Bill Share this post Link to post Share on other sites
Michael Ragan 12 #6 Posted May 9, 2022 On 5/5/2022 at 8:35 AM, squonk said: Mike, Napa / Gates 25-7345 Rubber edged cogged belt. Will get you right in the middle of the adjustment. Costs more than a 4L350 belt but it will grip better and run cooler. Notched design fits around smaller pullies easier. Belt Angle: 37 Deg Belt Construction: Notched Belt Material: Ethylene (EPDM) Brand: NAPA Cord Material: Polyester Cross Section Designation of Belt: HC41 Effective Length: 34.59 in Manufacturer: Gates Notched Belt: Yes Number of Strands: 1 Outside Circumference: 35.35 in SDS Required: No Top Width: .41 Hey Michael here , thank you so much for the info on the Wheel Horse 1045 belt. The old belt had completely rotted off and just crumbled to pieces Share this post Link to post Share on other sites
WHX?? 50,773 #7 Posted May 9, 2022 On 5/5/2022 at 7:35 AM, squonk said: Napa / Gates 25-7345 Sure that's a good number Squonky? My NAPA gave me the deer in the headlights..... can't find good help! The 1045/1055 K motor doe's not have ACR so would like to try a notched one. Share this post Link to post Share on other sites
squonk 42,579 #8 Posted May 9, 2022 51 minutes ago, WHX?? said: Sure that's a good number Squonky? My NAPA gave me the deer in the headlights..... can't find good help! The 1045/1055 K motor doe's not have ACR so would like to try a notched one. Did you give him the right number or maybe he needs a hearing aid! https://www.napaonline.com/en/p/NBH257345?impressionRank=1 https://www.napaprolink.com/Detailmi.aspx?R=NBG257345 Share this post Link to post Share on other sites
squonk 42,579 #9 Posted May 9, 2022 @WHX?? In case they want more proof, show them this! 3 Share this post Link to post Share on other sites
