Fishroe 261 #1 Posted May 4, 2022 I don’t need another one but I’m going to look at one tomorrow. This is the only pic. Seller says 339 hrs. Not running. Fuel pump went out but they have a new one in the box. Said it was running fine before the pump quit working. Looks like it has 2 levers on the column. I don’t know much about a hydro other than reading some threads on it. Does this have the Eaton 1100 and does it have hydraulic lift in rear. I think it might but needed to check with Yal folks What red flags should I be looking for and how do you disengage the trans so I can push it This is a similar situation as another thread I was looking at, gentleman passed away and kinfolks from another state are selling some of his belongings. They have another one, pretty rough looking, not running parts tractor. Can anyone identify it. I’ll try to post pic. Last time it wouldn’t let me post but 2 pics. I need to become a member. It let me this time. 2 3 Share this post Link to post Share on other sites
953 nut 56,753 #2 Posted May 4, 2022 (edited) The second picture appears to be a '67 long frame with a snow plow. These are great machines, wash off the bird poop and it will probably be a winner. The 314 is probably a 1994 or '95. Perhaps @Ed Kennell can answer the question on the eaton 1100 or 700 and the hydraulic lift. Rear lift was an extra cost option on these, cant tell from the photo. Edited May 4, 2022 by 953 nut 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,743 #3 Posted May 4, 2022 The rusty one looks to be a late 60’s model such as a Commando 8. The newer one has hydraulic lift and will be an Eaton 1100. One steering column lever is the direction control and the other is for the hydraulic up/down. 3 2 Share this post Link to post Share on other sites
Fishroe 261 #4 Posted May 4, 2022 Do you have to do anything to push it 1 Share this post Link to post Share on other sites
JCM 9,916 #5 Posted May 5, 2022 The manual for my 91 520-H that has the Eaton 1100 says it can be pushed at a slow speed. Move the motion control lever fully forward, tractor will then move when pushed. I have found on my 520 it does not like to be pushed. Moving the lever forward does not seem to do much. @Fishroe 1 1 Share this post Link to post Share on other sites
jamessparks 55 #6 Posted May 5, 2022 That 314-H has a clutch disengage lever right towards your right leg (sitting on the seat) to pull up. That can help for moving if it won’t start. Model #73401 most likely with a 1100 Eaton Trans. 1 1 Share this post Link to post Share on other sites
Fishroe 261 #7 Posted May 5, 2022 Thanks guys i would hate to drive 60 miles and then couldn’t get it on the trailer 1 Share this post Link to post Share on other sites
Pullstart 63,539 #8 Posted May 5, 2022 If for some reason you can’t open the tow valve, you can always tip the tractor with a heavy hip or hand and spin one rear tire opposite of the direction you’re pushing. With an open differential, it’ll move ok on three wheels. 2 Share this post Link to post Share on other sites
8ntruck 7,256 #9 Posted May 5, 2022 (edited) The Eaton 1100 does not have a tow valve. With the motion control lever in 'neutral', you should be able to push it at a slow walking pace. DO NOT TOW IT. Edited May 5, 2022 by 8ntruck 4 Share this post Link to post Share on other sites
Thor27 828 #10 Posted May 5, 2022 3 hours ago, jamessparks said: That 314-H has a clutch disengage lever right towards your right leg (sitting on the seat) to pull up. That can help for moving if it won’t start. Model #73401 most likely with a 1100 Eaton Trans. Won't help. That just disengages the engine from the trans, trans still has to roll, heads up, it will be noisy at least mine are.. 1 1 Share this post Link to post Share on other sites
Fishroe 261 #11 Posted May 5, 2022 Hopefully I’ll be able to push it up in the utility trailer 1 Share this post Link to post Share on other sites
953 nut 56,753 #12 Posted May 5, 2022 59 minutes ago, Fishroe said: Hopefully I’ll be able to push it up in the utility trailer If the tires are fully inflated there should be no problem at all. Like @8ntruck said, motion control in neutral, may be a good idea to make sure the parking break isn't set too. 1 Share this post Link to post Share on other sites
Fishroe 261 #13 Posted May 5, 2022 Little confused 300 series manual says to move motion lever forward when pushing. Yal are saying push it in neutral and that makes more sense to me 1 Share this post Link to post Share on other sites
8ntruck 7,256 #14 Posted May 5, 2022 My advice is based on the Eaton 1100 in my 1982ish C195. I assume that all Eaton 1100 transmissions operate in the same manner. If the transmission in the tractor you are considering is something different, treat it per reccomendations for whatever model it is. 1 1 Share this post Link to post Share on other sites
lynnmor 7,479 #15 Posted May 5, 2022 40 minutes ago, Fishroe said: Little confused 300 series manual says to move motion lever forward when pushing. Yal are saying push it in neutral and that makes more sense to me The hydros are very difficult to push no matter where the motion lever is. Your manual might say hand push only to prevent transmission damage. Get the trailer as close as possible to load. Pause every few feet to allow pressure to bleed back down. 2 1 Share this post Link to post Share on other sites
Fishroe 261 #16 Posted May 5, 2022 10 minutes ago, lynnmor said: The hydros are very difficult to push no matter where the motion lever is. Your manual might say hand push only to prevent transmission damage. Get the trailer as close as possible to load. Pause every few feet to allow pressure to bleed back down. Thanks i will do that just didn’t want to damage it the position of the motion lever was my concern or does it really matter this manual I printed out back in 2014 shows motion control lever on the side #13 not on the steering column 1 Share this post Link to post Share on other sites
Pullstart 63,539 #17 Posted May 5, 2022 All that fluid resistance will wear a guy out quick. I still support just tipping it enough for one tire to spin backwards. It seems like it takes less energy overall. 1 2 Share this post Link to post Share on other sites
Fishroe 261 #18 Posted May 5, 2022 I’ll try that if it gets too hard! 2 Share this post Link to post Share on other sites
Handy Don 13,085 #19 Posted May 5, 2022 7 hours ago, Fishroe said: My experience is that the lever position doesn't make all that much difference (my best position is slightly forward for pushing forward and slightly back for pushing in reverse) but the advice on SLOW MOVEMENT is very important. If you start to hear loud clicking, pause. That is the overload valves in the hydro opening and closing. 2 Share this post Link to post Share on other sites
kpinnc 13,106 #20 Posted May 5, 2022 (edited) 6 hours ago, Pullstart said: All that fluid resistance will wear a guy out quick. I still support just tipping it enough for one tire to spin backwards. It seems like it takes less energy overall. Or just pick it up and carry it to the trailer... All the previous suggestions here are good ones. Make sure the park brake is disengaged on the hydro. Expect to hear the ball pistons rattle a little bit. Mine sounds like marbles in a coffee mug if I move it more than a few feet. Don't be surprised if a small amount of the oil "burps" out of the filler tube. Especially if it's been sitting a while. Great find BTW! Edited May 5, 2022 by kpinnc 3 Share this post Link to post Share on other sites
Fishroe 261 #21 Posted May 6, 2022 Well here they are got a new fuel pump in the box, 3 new blades, a new oil filter and fuel filter and owners manual. Didn’t pay anything for the little tractor. The little tractor is pretty cool. Not locked up. I like the little hood latch. I didn’t know it had a lever and cable for lifting rear implements. Little tractor has a number below the dash 194163. Can anyone identify what year and model it is. You can cut grass and fish at the same time. 😂 Also is that a wheel horse sleeve hitch on the 312. Looks modified 339 hours no problem pushing it. Blade deck has no rust holes battery in little Tracy is 22 years old!! 275 for the 312 and 25 for the implements and that was their asking price. Husband and wife were really nice people 2 5 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #22 Posted May 6, 2022 No model number above the 194163 serial? Possibly a 1966 model 856 1 Share this post Link to post Share on other sites
Fishroe 261 #23 Posted May 6, 2022 (edited) Took a brush to it and you are right. It is an 856 I couldn’t make the number out in the picture that I posted but my pic on the phone it’s clearly an 856 number Edited May 6, 2022 by Fishroe 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #24 Posted May 6, 2022 2 Share this post Link to post Share on other sites
Fishroe 261 #25 Posted May 6, 2022 Thank you very much 1 Share this post Link to post Share on other sites
