Similar Content
By Rick Ferrucci
I think I'll be able to mount some rear view mirrors onto my GT14 dashboard housing. I can see that it's cast, but I don't know if it's steel or iron. Has anyone tried to drill into the the dash housing? Was it drillable? Thanks for help.
By Daron1965
I was just given a harbour freight 6.5hp predator engine. It started on second pull and seems to run fine. Im thinking of doing some experiments on it. I may buy some of the performance parts for it. Have any of you had any luck with aftermarket parts for these little engines?
By Mithral
Seeking guidance for tuning a CH18S Kohler Command (1995), as replacement for a 16hp Onan (1990).
This Kohler doesn't have the torque-grunt of this Onan, but it works, and is my available option.
So, how best to tune the Kohler for this application?
1. I believe Onan and Kohler high RPM setting are both 3600?
2. Would it hurt the Kohler to boost that RPM to 3700-3800? Would it really help any?
3. Would it hurt the Hydro Transmission to go over 3600rpm?
4. I guess I could go find a slightly smaller Drive Pulley? And what would then happen to the Trans if I can't get the proper RPMs to the Trans?
Now that I've figured out the mounting arrangements I can always swap in a bigger engine should I stumble upon a better option.
Given the difficulties of getting the Onan rebuilt now-a-days, I'm looking to go for a more modern engine with easier to find parts/service. And I'm not inclined to do an engine rebuild myself.
Thanks,
- L.
By ohiostate454
So I have been working on a 656 I picked up at the end of last year and I did my first ever motor rebuild by my self on it. However it seems that I have lots of play in the piston and some slop at TDC more then I should have. So to finish the year mowing I am thinking of doing a predator swap while I go over the engine again. I am sure several people have done this before and I have a spare mounting plat to make it work. I am wondering if anyone has any pictures of ones they have done for help along the way. I know I will need a adapter to use the factory pulley and I don't want to destroy any of the sheetmetal since it is in good shape. I will keep you posted as I go along and eventually when I get the hh60 back together correctly to re install.
By giddyap
This is my first born custom and is still under construction. Only one of the hoods, gutted frame, seat tray and seat are from my recently acquired 551 Suburban. A newer 3 speed transaxle and belt guard will round out the remaining Wheel Horse parts. The front axle is flipped and moved forward 6 inches. Its origin along with the tie rods and steering column comes from a 102 Cub Cadet. Taking 2 steps back for every advance is part of the fun. But now I'm at a loss and overwhelmed at all the V drive pulleys available at Phoenix pulleys. Can anyone suggest what pulley I should use with the 13 hp Predator? Thanks in advance
