41chevy 74 #1 Posted April 26, 2022 Where can I find throttle and choke handles for 1976 B 80 Share this post Link to post Share on other sites
SylvanLakeWH 27,593 #2 Posted April 26, 2022 Check “vendors” under classified section. Several of them may have what your looking for… Share this post Link to post Share on other sites
daveoman1966 3,814 #3 Posted April 26, 2022 I have two thr 'T' handles... Exactly the same and WILL FIT the choke lever... Neither is cracked or chipped. Perfect fit. $22.50 shipped to your mailbox. 2 1 Share this post Link to post Share on other sites
Lee1977 7,044 #4 Posted April 26, 2022 Wheelhorse Part and More has them. 2 Share this post Link to post Share on other sites
WHX?? 50,778 #5 Posted April 27, 2022 K & B @76c12091520h also has NOS ones. Share this post Link to post Share on other sites
peter lena 9,093 #6 Posted April 27, 2022 @41chevy , good opportunity to not only install new handles , but to lubricate and improve placement of those cables , often just backing off of a cable mount clip , lets the cable be where its wants to be, working easier . add some , SYNTHETIC, SUPER LUBE TO THOSE SLIDE AREAS , and related linkage movement points , and feel the difference . done that on all my linkage set ups , hard ware store might have that oil , definitely on line , only a suggestion , pete 1 Share this post Link to post Share on other sites
WHX?? 50,778 #7 Posted April 27, 2022 What the heck would we do without you greasy pete?!?!? 3 Share this post Link to post Share on other sites
peter lena 9,093 #8 Posted April 27, 2022 @WHX?? just a similar , cable service that I did , ever try to push a cable ? thats what led me to detail the function of that area . first it was , cable binding in its original setting , released that , easier movement . lubricated every related swing point , also added , light spring pulls at end of cable to adjustment arm area , always assisting pull back to close . like this , know this is a no no ,to many , cables work with total ease . very light spring pull , greasy , pete Share this post Link to post Share on other sites
JoeM 7,941 #9 Posted April 28, 2022 11 hours ago, WHX?? said: What the heck would we do without you greasy pete squeeeeeeeeak by! Pete is on it! or the grease is on it? Anyway...... I bet his stuff is smooth as butter! 1 Share this post Link to post Share on other sites
