tractorhogg
Spindle Size on D series Tractors
tractorhogg
A fellow told me some early D series tractors came with 3/4" front axle spindles, is the is true
Edited by tractorhogg
peter lena
@tractorhogg ,  not sure about the  spindles , am sure about the lubrication , those deck bearings , work under high speed and angular load ,  that 3/4 " bearing is a very common  ceiling fan bearing , more often than not filled with a generic " grease " , that vey quickly goes into a whining noise stage .  lucas  x  tra heavy duty chassis grease , 560 deg drop point , anti sling , polyurea ,rated  recovering , grease  , wallmart  $ 7 .  all my decks and related mule drive bearings have been changed over to this grease . no noise  or whining  operation , only a suggestion , greasy , pete
tractorhogg
I meant axle spindles
JoeM
I am thinking of the one I had in the inventory section of the yard. I think your guy might be right.
parts book says the 1974 d160 used 110513 bearings. 3/4 id
pacer
Yes, the earlier D's had 3/4" axle spindles, and I've had 2 D180s with 3/4". I think I saw that the 1" was an option on the 180s ?, and, of course my 2 D200s have the !"
76c12091520h
Just sold a bunch of them,  the early ones were 3/4", later one's were 1"
wh500special
Early ones were 3/4” and they were highly subject to breaking, especially when fitted with a loader.  There was a factory fix for it that replaced them and the front axle to 1” to solve the problem. It’s been discussed here before.   It wasn’t a recall, they only did it for customers that had problems.
I’ve never really thought the D-series was Wheel Horse’s best effort.  I think they found the upper end of their component durability limits with them.
steve
tractorhogg
steve
Still they were MUCH better than the Simplicity/Allis 4040/4041/620/720 tractors, while they were bigger, their 3 point lift cable system was junk, the hydro rear end was shoddy and the Onan 16/20 was way underpowered for that size of tractor, should have been a diesel. Talk about underpowered and underwhelming the Cub 154/184. tractors were pretty weak. About the only big GTs that could compete in the D series class and around 1974/1975 were the John Deere 400 and Bolens HT20, and Sears FF series
JoeM
Yep. Had a D160, not much on power. I could actually bog it down with the hydro.
I had the common hydro coupler issues with the o'rings that leaked from time to time on the steel tube lines running the rear hydro motor. I think the frame would twist slightly to cause the leaks.
I installed the same FEL on a 520H. The 520H was way better for work and dug much better.
D160 went west to a collector. Pretty much unmolested and had the rear PTO with 3 point.
Hydro cooling fan
pgiro
Anyone have a source for replacement 1" front wheel bearings for a D series?
Seems that I can only find 3/4" WH bearings.
76c12091520h
Wheel bearings for this application are non-existent. As hard as it is to believe, Wheel Horse was about the only application for this bearing and there is no crossover to any other manufacturer. The only thing you can do is watch for some that occasionally pop up on Ebay, or search for some nos bearings. I sold a couple sets in the last couple years, and they are not cheap.
pgiro
Good to know. Thanks.
tractorhogg
You can switch to a 5.70-8 tire and wheel and use 1" timken bearings, but you will have to use a dexter shorty cast iron 4 bolt hub. Steering is much easier and save wear on the steering components
tractorhogg
Hydro cooling fan
I've never experienced any overheating or leakage, but I'm only using the front blade and rear box blade on one D-160 and a 54" shaft drive tiller on the other, both are 16Hp kohler singles and they've never bogged down. I'm running 5/70-10 tires on 4 bolt 10"-3.75" steel wheels with cast tron trailer hubs and timken tapered bearings
JoeM
that is a nice up grade.
That 16 onan was on the tired side. add in the weight and FEL not mention the taller tires it was lackluster.
A couple pics after I completed the build. I did get a lot of work out of it.
JoeM
No overheating, the pic was just for reference. that fan was a OE installation.
tractorhogg
Do you mean Wheel Horse put these fans in new tractors?
JoeM
Yep, part #107510
tractorhogg
9 hours ago, JoeM said:
Yep, part #107510
WOW,  very cool
  • Haha 1
pacer
I've bought 2 of the D's with the fan ..... and neither worked! frozen up ... lack of use?? I just took em off and pitched em, none of my other D's had them anyway.
pfrederi
Fans are a good idea but you cannot use that style if you have the easy ride seat.  I wound up using a small 4" box style fan..
