oliver2-44 10,367 #1 Posted April 24, 2022 I need a pump sprayer to spray my two 30 ft tall pecan trees. Last year my Pecann crop was ruined by black aphids and tiny green stink bugs I have a Tractor Supply 25 gallon electric sprayer I use for spraying small mesquite at the farm, but it won't reach high enough or put out enough volume to cover a big tree. https://www.tractorsupply.com/tsc/product/fimco-25-gal-deluxe-spot-sprayer-5302938-1350428?store=561&cid=Shopping-Google-Organic_Feed-Product-1350428&cid=Shopping-Google-LOB-Local_Feed&utm_medium=Google&utm_source=Shopping&utm_campaign=LOB&utm_content=Local_Feed&gclid=Cj0KCQjw6pOTBhCTARIsAHF23fKeN6hiYqVX_oRo7DDz3XMOeejd6M3a_14k3fnxKG36MX-hmgUfT4waAid5EALw_wcB I've looked at replacing the pump but haven't really found or figured out what I need pressure/flow wise. To spray 30 ft high I will need a minimum of 60 psi plus a little more for system losses, so I probable need a pump that will do 75-100 psi. then there is the GPM flow question. Back when i was in high School (1970's) years ago we had a green double roller pump that mounted on the tractor PTO. I wish I knew what it was, it would really put out some volume and that want would hoot it high. My options seam to be find a higher pressure and higher volume 12v electric pump. or, I could always mount a belt driven pump of the PTO on the front of a Wheelhorse and put my existing tank or a plastic barrel in a trailer behind it. Anyone have experience or knowledge with spray pumps and spray wands setups, factory or shop built. Thanks in advance. 1 Share this post Link to post Share on other sites
Pullstart 64,531 #2 Posted April 24, 2022 Could you run a 540 PTO pump off a larger tractor? Is a the perfect footprint for between the trees? 1 Share this post Link to post Share on other sites
oliver2-44 10,367 #3 Posted April 24, 2022 My larger 45hp 10,000 lb tractor is at the farm 2 hours from here. So I’m hoping to do this wit a WH or 12v or 120v electric. A 12-16 hp Kohler should have plenty of power 1 Share this post Link to post Share on other sites
pfrederi 18,329 #4 Posted April 24, 2022 Get the 540 PTO kit (8-3211) for your WH and use the roller pump from your big tractor Share this post Link to post Share on other sites
roadapples 6,983 #5 Posted April 24, 2022 Would a longer wand help... 1 1 Share this post Link to post Share on other sites
Pullstart 64,531 #6 Posted April 24, 2022 1 hour ago, roadapples said: Would a longer wand help... I imagine a 30’ wand on a 500 lb. machine would be fun in a wind storm! 2 Share this post Link to post Share on other sites
pfrederi 18,329 #7 Posted April 24, 2022 I am having a similar problem with a big maple tree. I have a northern hydraulic system similar to the one you showed. It has max pressure rated at 200 lbs 2.0 GPM only shoots about 30 ft high. Pressure gauge will work up to just under 200 nozzle off but even with smallest orifice they provided it drops to about 60 (manual claims it should hold 110 withe small orifice...) Share this post Link to post Share on other sites
oliver2-44 10,367 #8 Posted April 25, 2022 11 hours ago, pfrederi said: Get the 540 PTO kit (8-3211) for your WH and use the roller pump from your big tractor Regrettable that roller pump died many years ago spraying fence lines. I believe it may have dated back to the earl 50’s when my dad had the Dairy and used it to spray the dairy cattle. Share this post Link to post Share on other sites
kpinnc 13,728 #9 Posted April 25, 2022 (edited) Hypro still sells roller pumps. I have one set up on my sprayer so it connects to my 310-8. I run it about 1/2 throttle with a 7-ish inch pulley. Hooks up like the tiller idler setup. https://www.tractorsupply.com/tsc/product/hypro-8-roller-cast-iron-sprayer-pump Edited April 25, 2022 by kpinnc Share this post Link to post Share on other sites
kpinnc 13,728 #10 Posted April 26, 2022 On 4/24/2022 at 9:37 AM, oliver2-44 said: To spray 30 ft high I will need a minimum of 60 psi plus a little more for system losses, so I probable need a pump that will do 75-100 psi. then there is the GPM flow question. I don't know what the GPM on my setup is, but it makes about 125 psi. My tank is 27 gallons, and with the arms folded out and all nozzles spraying, it goes in about an hour, maybe less. My tank has a bypass on it, so I can't even make a decent guess. Mine is a Hypro silver (stainless) 4 roller pump. The 6 and 8 rollers are likely higher GPM. I made a bracket so my pump mounts in the belly hitch, and the weight of the pump holds belt tension. It works very well, though I don't run the tractor over 1/2 throttle. 1 1 Share this post Link to post Share on other sites
oliver2-44 10,367 #11 Posted August 6, 2024 I'm still needing to rig up a sprayer. I know you use the tank spray arms, but if you have a hand spray wand could you post a picture of it? On your pump mount, what do you connect the other end of the spring to? Thanks for your assistance. I'd also appreciate any comments from someone that has pump/sprayer design experience. Share this post Link to post Share on other sites
Lee1977 7,037 #12 Posted August 7, 2024 (edited) I have a 4 roller pump like shown at Tractor Supply 7.2 gpm 150 max pressure , continuous operation 100 psi 2600 rpm 3/4" in and out The 6 roller pump Tractor Supply 22 gpm 300 max pressure continuous operation 150 psi 1200 rpm 3/4" in and out The 8 roller pump Tractor Supply 22 gpm 300 max pressure continuous operation 100 psi 1000 rpm 3/4" in and out To give you a general idea of the different pumps I got mine some 30 years ago. I could get 90 psi with an old 3/4 HP Briggs washing machine engine, I used a valve to dump some back into the tank to control the pressure. When you store the pump get all the water out and fill with oil. Edited August 7, 2024 by Lee1977 Share this post Link to post Share on other sites
JPWH 6,251 #13 Posted August 7, 2024 Maybe you could adapt something like this. https://www.amazon.com/janz-Telescoping-Pressure-Extension-Attachment/dp/B0B4D85FCC/ref=asc_df_B0B4D85FCC/?tag=hyprod-20&linkCode=df0&hvadid=693711674086&hvpos=&hvnetw=g&hvrand=10608777674528989564&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9010912&hvtargid=pla-1952323792526&psc=1&mcid=f782450d069435f189dd0e72c7c0a067&gad_source=1# Share this post Link to post Share on other sites
wallfish 17,492 #14 Posted August 8, 2024 I don't have the experience, but if you have the large supply tank and a pressure washer, could the tank feed that? Those things shoot 30 ft. Most can also draw "soap" but using that to draw pesticide instead of mixing it in the tank will allow it to be flushed afterwards. Just kinda think'n out loud again 1 Share this post Link to post Share on other sites
oliver2-44 10,367 #15 Posted August 9, 2024 15 hours ago, wallfish said: I don't have the experience, but if you have the large supply tank and a pressure washer, could the tank feed that? Those things shoot 30 ft. Most can also draw "soap" but using that to draw pesticide instead of mixing it in the tank will allow it to be flushed afterwards. Just kinda think'n out loud again I’ve toyed with that idea. One of the challenges is I can’t find any info on how much they draw. I need to get the fungicide mixture relatively close. I’ve read too much can burn the trees leaves and of coarse to little doesn’t get results. Share this post Link to post Share on other sites
wallfish 17,492 #16 Posted August 9, 2024 31 minutes ago, oliver2-44 said: I’ve toyed with that idea. One of the challenges is I can’t find any info on how much they draw. I need to get the fungicide mixture relatively close. I’ve read too much can burn the trees leaves and of coarse to little doesn’t get results. Maybe it could be measured in real time with the exact equipment and conditions. Run 5 measured gallons of water from the supply tank with a measured 1 qt of water in the pick up supply and the math would give a mix ratio for the pesticide. Share this post Link to post Share on other sites
