ANTPER
Brake Adjustment 310-08
ANTPER
Hello Crew
I had no braking with my tractor and noticed the brake band was million miles away from my and I'm gonna call it brake drum. I tightened up the nut and got the band right up on top of drum. Stops great now but now to use it as a parking brake its not working. I cant get the parking brake lock lever to stay in place to keep brakes lock. Did I over adjust the brakes to tight or close to the drum?
WHX??
Might be a little tight. Back off on it a little at a time until the park just catches. Might have some worn brake band material too.
OutdoorEnvy
Yes you tightened it too much.  Back it off a turn or two at a time until the parking lever can lock in place.
ANTPER
Okay, looks like that did the trick. Thank you Gentlemen. BTW Thank you for you service WHX??
