ANTPER 207 #1 Posted April 23, 2022 Hello Crew I had no braking with my tractor and noticed the brake band was million miles away from my and I'm gonna call it brake drum. I tightened up the nut and got the band right up on top of drum. Stops great now but now to use it as a parking brake its not working. I cant get the parking brake lock lever to stay in place to keep brakes lock. Did I over adjust the brakes to tight or close to the drum? Share this post Link to post Share on other sites
WHX?? 50,778 #2 Posted April 23, 2022 Might be a little tight. Back off on it a little at a time until the park just catches. Might have some worn brake band material too. 3 Share this post Link to post Share on other sites
OutdoorEnvy 1,734 #3 Posted April 23, 2022 Yes you tightened it too much. Back it off a turn or two at a time until the parking lever can lock in place. 1 Share this post Link to post Share on other sites
ANTPER 207 #4 Posted April 23, 2022 Okay, looks like that did the trick. Thank you Gentlemen. BTW Thank you for you service WHX?? 1 Share this post Link to post Share on other sites
