KC9KAS
Voltage Regulator
KC9KAS
Need assistance! 1977 Wheel Horse C-120 hydro.
I sold it to a young fellow last fall.
His dad said he put a new battery in it but it still failed to turn over to start.
I checked the only safety switch (with an ohm meter) and it is working correctly.
I checked all the wires (ohm meter) and they tested ok. I did come to the conclusion the 20 amp AMP gauge was bad.
I installed an old one that I had and it turned over and started right up.
I already had the voltage regulator wires disconnected and read 36 VAC from the stator.
When I attached the wires to the (fairly new) voltage regulator it would immediately cause the engine to sputter and die.
The voltage regulator is grounded directly to the negative post on the battery.
Once the wires were removed from the voltage regulator it would fire right back up!
I am at my wits end trying to figure this one out! Would a bad voltage regulator cause the engine to quit running? I may have to remove a voltage regulator from another known good machine and try it.
Anyone have any suggestions?
Achto
Does this tractor have a battery ignition coil? Did some one by chance change the ignition coil? Or run a new positive wire to the coil, possibly eliminating a resistor wire? If a coil that requires an external resistor is installed on a Kohler, it will work until the voltage to the battery starts to increase as the charging system starts to work. I fought this issue on my C-145, thought that the charging system was pulling it down but really it was the wrong coil. Engine would run for a short while & then it would bog down almost like it was under load and quit. It would run fine with the regulator unplugged.  I discovered that it had the wrong coil, installed a coil with an internal resistor and the tractor has ran great ever since.
Edited by Achto
  • Like 4
KC9KAS
It ran and worked properly for several years before I sold it last fall. I know the family that I sold it to have not done anything to it.
I am just stumped on this one!
Edited by KC9KAS
  • Confused 1
Achto
If you have a coil laying around maybe try it on the tractor. There is a possibility that the original failed.
R Scheer
Internal short in the voltage regulator may be drawing the voltage down, possibly causing the coil to not have enough voltage.  Just a thought.
Maybe check the voltage without the regulator connected, and with it connected.
  • Excellent 2
953 nut
Is the BODY of the regulator grounded to the negative post on the battery? There are two AC Voltage terminals on the regulator and one DC terminal. The DC terminal (disconnected from the regulator) should read battery voltage (12 volts DC) with the key in the on position but not running. Once you have confirmed this attach the wires to the regulator and see if the 12 volts is there. Could be an internal short in the regulatorpulling the voltage down.
953 nut
:confusion-confused:        been sitting all winter, check the wires for rodent damage.
KC9KAS
Yes. I used one of the VR mounting holes.
It was stored inside an attached heated garage. No evidence of rodents.
  • Similar Content
    • JasonMc
      By JasonMc
      Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
      Jason
    • WHX??
      By WHX??
      Sadly Dan @Achto informed me the the other day of a 857 and a C-120 that was deposited at his local county dump. Dump rules are  such that once it hits the ground it stays due to junkyard dogs going to fisticuffs over scrap steel. Understandable  Despite some hastily made plans of bribery,  chicanery and/or hook or crook to rescue them we failed miserably. We may get drummed out of the Mafia for that one.
      I'll let Dan fill you in on the details if he has the stomach.  I would like to believe that that our beloved  ones would be smelted down to produce more tractors but then I wake up from that dream. Sorry no bone yard pics not that we would want to see them.
      Dan asked me if he had a problem over grieving over these lost gems. You decide... So in memoriam I feel it is quite nescessary to post pics of our lost loved ones. Since I don't have a C-120 here's what I have of a 857.  Please post your pics of either models. True story, I wouldn't hose you guys and not just fishin  for
    • 608KEB
      By 608KEB
      One seat spring is about 1/4" lower than the other one. Has anyone had this problem. If so, what'd you do to fix it?
    • Tuneup
      By Tuneup
      Homer is a typical Southern man. When a tool breaks, he moves it to his backyard to be repaired another time. Turns out I'm the repair guy and have been attempting to barter for an old C-120 and a Commando 7 buried in the yard. He surprised me with the C-125 black hood a while ago after numerous mower, chain saw, weed wacker and whatever repairs. The horses are all out of a shop in Joplin now gone after the big blow... Soooo, 1 repaired old Sears LT and another that I took apart just so he could see after running without oil that the cam was in 4 pieces and the rod in 5 and he said I could have the 120. We pulled it out of the dirt with 4 flats, destroying several ant mounds in the process. Truly, not bad condition thanks to Homer's attention to the use of tarps. He tells me the 301 was bored .030 over and his mind is sharp for a 92 year old so I'm inclined to believe him. May be able to save that Commando in the near future if I repair that old Bolens GT14 first - and so on. So, my collection is now at a lowly 2. I don't think I'll restore this - will just make her a reliable runner and make the wife happy The deck can use a little metal but seems salvageable. Another C saved!
    • 608KEB
      By 608KEB
      I sold this last fall. 1975 C-120 Auto. The buyer called and asked if I wanted it back. I couldn't  say no. He put about 4-5 hours on it. The war dept. told him him he had to chose between a motorcycle or the WH.
