JCM 10,023 #26 Posted April 19, 2022 If you don't check EVERYTHING on that 520, you will wish you had considered those. @binna 2 1 Share this post Link to post Share on other sites
lynnmor 7,576 #27 Posted April 19, 2022 I'm seeing a number of minor things: Seat is spent Engine has been rewired. 9 pin connector was hot. Left rear axle seal is leaking. Battery hold down is missing. Air filter sensor is broken and its hose is sucking dirt. Fuel line pulled tight at pump and too much slack at rear. May not be original engine. Sloppy wiring at transaxle. 3 Share this post Link to post Share on other sites
kpinnc 13,780 #28 Posted April 19, 2022 3 hours ago, JCM said: JMO I would offer 750 and go from there. Can't argue with that. All he can say is no. WH tractors are getting rare down here, and I wouldn't give that much for an 88 with 1000 hours. But that is just my opinion. 3 Share this post Link to post Share on other sites
Ed Kennell 40,513 #29 Posted April 19, 2022 Yep, it went from a '93 with 300 hours for $1500 to a '88 with 1000 hours. The deck looks OK with new blades. If it starts easy runs well from 500 to 3600 RPM without surging and will spin the tires when fastened to a tree,and mows OK, I would start at $700. 5 Share this post Link to post Share on other sites
JoeM 7,941 #30 Posted April 19, 2022 For 1100 hour machine, and all the issues........ that is telling you a story. If you are not super handy and have time to spare, probably should move on. Cutting a half an acre, there are much better and easier to work on wheel horses. A nice 312-8 or even a 312 or 314 H would be a much better choice. Plenty of power and less wiring issues for sure. 42 inch decks give a nice cut too and there are options for side and rear discharge. 5 Share this post Link to post Share on other sites
WHX?? 50,776 #31 Posted April 19, 2022 (edited) Gotta side with the others on value. Even mentioning the issues to the seller to see if he would come down on price I would still walk away. Just better deals out here to be had. I bought a 600 hr 94 with a cab, blower, tiller, generator & lawn vac for 1750. Sure had to travel abit for it but still. Just too big of a risk if your looking for plug & play. Now if you were looking for a project and could get it for say 500... different story. Personally I would stay away from it and look for better. Joe nailed it. Gotta like your sense of humor tho! Edited April 19, 2022 by WHX?? 7 Share this post Link to post Share on other sites
JCM 10,023 #32 Posted April 19, 2022 1 hour ago, JoeM said: Cutting a half an acre, there are much better and easier to work on wheel horses. A nice 312-8 or even a 312 or 314 H would be a much better choice. 3 Share this post Link to post Share on other sites
DougC 2,642 #33 Posted April 19, 2022 What the Hell... I read it had 300 hours and was a much newer machine when I made my original post.... Lets get our **** togather and start over. I may post a totally different opinion! 1 Share this post Link to post Share on other sites
squonk 42,581 #34 Posted April 19, 2022 (edited) See the large bolts on the engine? If you get any 520, make sure all of these are tight! It's the crankshaft bearing retainer. I had these loosen up on my 520 and I ended up with over a quart of oil on the ground in no time! If I was looking for a tractor to mow 1/2 acre with ease of maintenance in mind I'd skip all of the 300-500 series and look for a C-120, no name 12 or Raider. IMHO. Less tin work and better quality steel. Edited April 19, 2022 by squonk 2 Share this post Link to post Share on other sites
binna 26 #35 Posted April 19, 2022 (edited) hi folks- i definitely passed on the machine. yep, 1000hrs! not the 300 i was told on the phone. i have done some thinking and some more reading/watching. i am looking for a lawn tractor not a mower. i have gates, beds, trees, bumps, slope, really thick areas (grass) and some normal and crap grass areas. I want power steering and a machine that can handle a blade. a 42-46" deck would be plenty. a hydro deck would be a plus but not a deal breaker. i can change fluids and filters and probably belts, those types of things. electrical/carb/tran work is above me i really appreciate everyone's feedback. it's nice to have folks to give their .02. Edited April 19, 2022 by binna 4 Share this post Link to post Share on other sites
binna 26 #36 Posted April 19, 2022 @squonk what is a "no name 12"? 1 Share this post Link to post Share on other sites
squonk 42,581 #37 Posted April 19, 2022 8 minutes ago, binna said: @squonk what is a "no name 12"? 73 12HP Basically a C-120 but instead of saying C-120 on it it will just have a 12 1 Share this post Link to post Share on other sites
binna 26 #38 Posted April 19, 2022 they are just so nice to look at! 1 Share this post Link to post Share on other sites
