Brockport Bill
Seat mounting holes???
Brockport Bill
See photos ---- I have a seat with 2 missing hole anchor tabs on the back -- thus, no threads for seat bolts to screw into? The seat is in excellent condition but the seat is missing two of the 4 "female" anchor tabs. Does anyone know of a solution for this problem? thanks
  • Sad 1
lynnmor
Remove the upholstery and then spot weld in something like this.  You could make them for an exact fit.
953 nut
peter lena
@Brockport Bill , agree with @953 nut on the slide in type of  base nut , my local hardware  store has , loads of pull out drawers , with that type of  attachments.  look around , with the what if , frame of mind , probably find just what you want , pete
peter lena
@Brockport Bill  there is practically no problem that I  encounter, that  that  don't look at from a number of angles , that  regular mind  set very often gives me a chance not only to correct the original problem ,  but too often enhance that . for those that have to have original , there is but one choice . having gone rogue many years ago , its just how I look at things , off the cliff , pete
roadapples
I use nutserts. They have different names but basically a pop rivet with threads...
lynnmor
Finding one for a large square hole and a 5/16-18 thread might be tough.
roadapples
I've seen them in 3/8x16 but yeah those holes may be large...
Brockport Bill
been to 4 stores today -- inlcuding one "old time" hardware store -- no luck - the closest solution is a license plate plastic insert ( that pops into truck car tin/bumper etc) with expandable back/bottom side like a molly or toggle would expand when bolt/screw inserted?????????
JoeM
Anyway to fish a carriage bolt from inside out, useing it like a stud? :confusion-shrug:
Bill D
I'm not sure that would hold the seat in place safely.  The original nuts are probably still in there but the cover and padding will have to be removed to fix it properly.  I have a nutsert tool but I don't think it will work with those square holes.
953 nut
If you cut a slot in the metal seat pan the correct size and distance from your existing square hole you can slide this type of fastener into the slot (nut side inside) and line it up to the hole. Auto parts stores carry them in a variety of sizes.
Auveco J Type Cage Nut (sold by each), 5586
johnnymag3
Davies Hardware may have them....also I know Williams Lumber has a ton of that stuff....
I know Bill, both of them know where these stores are !!   :)
Brockport Bill
ive tried to see if this type clip would ( since they are commonly used for the WH tin ) work but having it stay fixed in the hole has not yet worked but i will think through the slot cutting idea? thanks
Brockport Bill
i've so far avoided the removal of the cushion fearing doing damage -- but that will be my last resort solution -- which may have to be only option - thanks
Lee1977
I took one apart on a Gilson. The hardest part was the little metal clip that held the bindings together. Don't know if the foam is glued to the seat pan, it may be. If you have to take it apart finding another pan may be easer then
fixing the one you have,
Brockport Bill
been to both -- no obvious solution from their inventory
  • Sad 1
Brockport Bill
actually since i see so may destroyed seat cushionss online i actually thought since i have a good condition vinyl and cushion that getting a used seat shell might be best option since they may be widely available
edgro
Weld in a flange nut. If you do one small weld at a time and immediately cool it with a spray of water, it shouldn't bother the foam too much. image.png.ef1b2e3cbc3bbc86a37db78a15673450.png
JoeM
47 minutes ago, Brockport Bill said:
removal
I was thinking to leave the cover on an used a wire from the large hole to hole  kind of like when putting in bumper bolts in a box frame
lynnmor
I have removed and reinstalled cushions a number of time, none of mine were glued.  Give it a try, it may be a piece of cake.
roadapples
I really think those cage nuts would work. Also can't tell by the picture which are missing. I've used only the 2 fronts. Don't have to worry about the seat tilting forward, only backwards....
Brockport Bill
the two front holes -- so yes, a bit unsettling if leaning back
  • Sad 1
