![MachXXII](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Similar Content
By D_Mac
Going to possibly pick up a bolens 1256 that's been sitting outside for sometime. My question to any of you who have had one or knows about them is how to get them to free wheel. I would need to push it from a field to a driveway. From what I have read there is a pin on the right hand side, on the hub of the rear wheel that you pull out to get the wheel to free spin. Is there any other tow or dump valve on these machines? Also any thoughts on this model in general. Never had one before. Also never have had a wisconsin engine either. What should I expect?
By BuffaloD200
'74 D-180
My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
So my thoughts are grab a BFH or sparky the blue tip wrench.
Is there an unpublished step 3.5, or some trick?
By cJ_3D
Hello everyone!
Thought I would post a new thread on this as I wasn't able to find the information I was looking for. But I'm trying to get this drive belt on my 252-H and no matter what I try I can't get it on. I got a 1/2" x 76" so I know its the correct size belt. I followed the steps outlined in the manual which I've attached, and is shown on page 15. So I loosened the cross bar nuts and the flat idler adjustment pulley. And followed the routing from this guide: http://outdoorpowerinfo.com/repairs/wheel_horse_hydro_252-h_drive_belt.asp
I just can't get enough slack on it to get it over the engine pulley! Right now it's pinched up between the body and the pulley so possibly I can't get enough leverage, do I need to somehow work it from below the pulley? Doesn't help the pulley keeps coming off the shaft so I have it propped up using a scissor jack which is cumbersome to work around. I don't have a shop or anyway I can think of to safely stand the mower up and not sure about tipping it on it's side. Anyone who has done this particular belt on this mower before have any tips or suggestions for how to get this thing on?
Thanks for the help friends!
CJ
492-4003 Eaton 7 & Peerless 1320 SM.pdf
By Jon Paulsen
Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
By PWL216
Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
