stevasaurus 22,742 #1 Posted April 12, 2022 Going through some tools I inherited was this. I think I know what it is and what it is used for, but thought maybe someone out there knows for sure. This is made by Snap-On, uses a 1/2" drive ratchet. The lighter next to it gives it a reference for size. 4 Share this post Link to post Share on other sites
oliver2-44 9,756 #2 Posted April 12, 2022 Stud Remover 12 Share this post Link to post Share on other sites
Racinbob 11,082 #3 Posted April 12, 2022 (edited) Possibly some sort of torque multiplier Steve? Edited April 12, 2022 by Racinbob 2 Share this post Link to post Share on other sites
Snoopy11 5,714 #4 Posted April 12, 2022 I also have one of those in my shop @stevasaurus... I'm interested to see what it is used for as well. Don 1 1 Share this post Link to post Share on other sites
Racinbob 11,082 #5 Posted April 12, 2022 8 minutes ago, oliver2-44 said: Stud Remover We posted at the same time. I like your answer better. 2 1 2 Share this post Link to post Share on other sites
ebinmaine 67,530 #6 Posted April 12, 2022 1 minute ago, oliver2-44 said: Stud Remover I was thinking it would tighten/loosen something round. This makes sense/cents. 3 Share this post Link to post Share on other sites
Snoopy11 5,714 #7 Posted April 12, 2022 Just now, Racinbob said: We posted at the same time. Hahahaha... yeah, looks like we all posted at nearly the same time... Don 1 1 Share this post Link to post Share on other sites
squonk 41,121 #8 Posted April 12, 2022 Yup a stud remover. 6 Share this post Link to post Share on other sites
stevasaurus 22,742 #9 Posted April 12, 2022 Excellent gentlemen...thanks. How about this one??? It's a little beat up...Grandpa was a Truck Mechanic in Chicago. One thing, he bought good name tools...Snap-On, Craftsman, Thorsen, S-K, Indesko, Some of them are from the 30's...names gone by. This one looks like a screw driver for a 1/2" drive ratchet. The blade is 7/8" long and 1/16" thick. I think it is a wedge that might split a transmission...can't think of a screw that big on a truck?? This is a Craftsman. 1 Share this post Link to post Share on other sites
JoeM 7,874 #10 Posted April 12, 2022 (edited) I seen these slotted drivers uses on tie large tie rod ends. Some large machinery used tie rod ends that had cups that clamped to a ball. (similar to a trailer ball). In the end of the rod was a spring that tightened against the cup and a large slotted nut would turn in tension against the spring. When tight, the slot was lined up with holes in the housing and a cotter pin went down through the slot and locked it all in place. Edited April 12, 2022 by JoeM 5 1 Share this post Link to post Share on other sites
stevasaurus 22,742 #11 Posted April 12, 2022 I had no idea, but I have used the forked tool on tie rods on cars and light trucks. Do you think I should file it and clean it up?? I doubt I would ever use it. 2 Share this post Link to post Share on other sites
Achto 27,587 #12 Posted April 12, 2022 1 hour ago, stevasaurus said: Back in my days of wrenching on Harley's, I could have used a tool like that to remove inspection plugs from Iron Head Sportster primary covers. I actually made myself a tool out of some flat stock with a nut welded to it to do the job. 3 1 Share this post Link to post Share on other sites
squonk 41,121 #13 Posted April 12, 2022 Drag link socket. Some links have a slotted screw in one end. The screw, tightens down onto a stud on another steering link and is locked with a pin. My 85 Toyota pick up had one of these links. 7 1 Share this post Link to post Share on other sites
pfrederi 17,741 #14 Posted April 12, 2022 21 minutes ago, squonk said: Drag link socket. Some links have a slotted screw in one end. The screw, tightens down onto a stud on another steering link and is locked with a pin. My 85 Toyota pick up had one of these links. Old farm tractors and military vehicles you need a set... 5 1 Share this post Link to post Share on other sites
953 nut 55,260 #15 Posted April 12, 2022 1 hour ago, stevasaurus said: This one looks like a screw driver for a 1/2" drive ratchet. The blade is 7/8" long and 1/16" thick. Not just for trucks, The adjustment plug (6) of a 953's Ross steering could make good use of it too. 4 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,309 #16 Posted April 12, 2022 I have a few of those in one of my tool boxes , they were the old man's , he worked on machines that corrugated paper to make shipping boxes. 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,577 #17 Posted April 13, 2022 3 hours ago, oliver2-44 said: Stud Remover Why would you want me removed? 9 Share this post Link to post Share on other sites
Horse Newbie 7,070 #18 Posted April 13, 2022 5 hours ago, oliver2-44 said: Stud Remover I don’t need a “stud remover”… if someone asks me to leave, I’ll go… 4 Share this post Link to post Share on other sites
Horse Newbie 7,070 #19 Posted April 13, 2022 3 hours ago, pfrederi said: My 85 Toyota pick up had one of these links. My 1981 Hi-Lux 4x4 pick up has one too, on the drag link,,, 1 Share this post Link to post Share on other sites
Horse Newbie 7,070 #20 Posted April 13, 2022 4 hours ago, JoeM said: I seen these slotted drivers uses on tie large tie rod ends. Some large machinery used tie rod ends that had cups that clamped to a ball. (similar to a trailer ball). In the end of the rod was a spring that tightened against the cup and a large slotted nut would turn in tension against the spring. When tight, the slot was lined up with holes in the housing and a cotter pin went down through the slot and locked it all in place. This is the exact set up on my 1981 Toyota Hi-Lux 4x4… 1 Share this post Link to post Share on other sites
Horse Newbie 7,070 #21 Posted April 13, 2022 4 hours ago, stevasaurus said: Excellent gentlemen...thanks. How about this one??? It's a little beat up...Grandpa was a Truck Mechanic in Chicago. One thing, he bought good name tools...Snap-On, Craftsman, Thorsen, S-K, Indesko, Some of them are from the 30's...names gone by. This one looks like a screw driver for a 1/2" drive ratchet. The blade is 7/8" long and 1/16" thick. I think it is a wedge that might split a transmission...can't think of a screw that big on a truck?? This is a Craftsman. I have a set of those, 1/2 inch drive… never used them… 1 Share this post Link to post Share on other sites
prondzy 3,881 #22 Posted April 13, 2022 5 hours ago, stevasaurus said: Excellent gentlemen...thanks. How about this one??? It's a little beat up...Grandpa was a Truck Mechanic in Chicago. One thing, he bought good name tools...Snap-On, Craftsman, Thorsen, S-K, Indesko, Some of them are from the 30's...names gone by. This one looks like a screw driver for a 1/2" drive ratchet. The blade is 7/8" long and 1/16" thick. I think it is a wedge that might split a transmission...can't think of a screw that big on a truck?? This is a Craftsman. Also used in a hand impact driver set. 2 Share this post Link to post Share on other sites
dclarke 4,032 #23 Posted April 13, 2022 Steve, I have one of those stud removers, made by S-K Tools. 2 1 Share this post Link to post Share on other sites
stevasaurus 22,742 #24 Posted April 13, 2022 Excellent guys...thanks!! The knowledge here is amazing. I am going to clean up the screw driver socket. 1 Share this post Link to post Share on other sites
squonk 41,121 #25 Posted April 13, 2022 Here is the drag link on my Power King. 2 1 Share this post Link to post Share on other sites
