Mickwhitt 4,621 #1 Posted April 12, 2022 Hi all. I've just felled a couple of diseased trees. They weren't quite dead but are still wet. I've sawn them into logs of the right length for my stove. Do I leave them To dry before splitting them with an axe? Is it easier to do or is there not much difference between fresh wood and dried. Mick Share this post Link to post Share on other sites
ebinmaine 67,463 #2 Posted April 12, 2022 Ease of splitting when wet or dry depends on the species. We find maples, oak, Birch to split fine wet or dry but Beachwood when dry is a knotted up twisted up tough mess. Either way, they need to be split to cure appropriately. 4 Share this post Link to post Share on other sites
WHX?? 48,815 #3 Posted April 12, 2022 What flavor is it? Smaller stuff will dry on it own but anything larger than say 4 in. or 10 CM should be cracked open. it will dry faster. As much as important is to keep it under cover and not use it for at least a year depending on species. We call that "seasoning" here Mick. Best to try and split it and see if it is stringy. If it is let it dry abit first. 2 1 Share this post Link to post Share on other sites
Ed Kennell 38,165 #4 Posted April 12, 2022 I used the axe and wedges for 40 years and most wood splits best when green. Now, my hydraulic splitter doesn't care .....green or dry. 6 Share this post Link to post Share on other sites
WHX?? 48,815 #5 Posted April 12, 2022 (edited) 2 minutes ago, Ed Kennell said: I used the axe and wedges for 40 years My shoulders hurt just thinkin about that! Although when I was younger.... My dad used to ream me good for busting the maul handle! Edited April 12, 2022 by WHX?? 4 3 Share this post Link to post Share on other sites
stevasaurus 22,729 #6 Posted April 12, 2022 I find wood splits best, by hand, when froze in the winter. 5 Share this post Link to post Share on other sites
ebinmaine 67,463 #7 Posted April 12, 2022 3 minutes ago, stevasaurus said: I find wood splits best, by hand, when ..... ....... Done by somebody else! 5 6 Share this post Link to post Share on other sites
Achto 27,570 #8 Posted April 12, 2022 2 hours ago, WHX?? said: My dad used to ream me good for busting the maul handle! " hit the chunk of wood with the head, not the handle!!" That's what was yelled at me. 1 7 Share this post Link to post Share on other sites
Handy Don 12,217 #9 Posted April 12, 2022 (edited) i used to yell at myself when I did that. "Can't you hit it straight, Don? What'sa matta with you!? (subsequent expletives deleted)" Finally got a fiberglass handle with a protective sleeve and NOW I've stopped missing--go figure. Edited April 12, 2022 by Handy Don 3 Share this post Link to post Share on other sites
ebinmaine 67,463 #10 Posted April 12, 2022 10 minutes ago, Handy Don said: i used to yell at myself when I did that. "Can't you hit it straight, Don? What'sa matta with you!? (subsequent expletives deleted)" Finally got a fiberglass handle with a protective sleeve and NOW I've stopped missing--go figure. Interesting. I followed a similar path. I couldn't keep a wooden handle on a splitter to save my bacon so I purposefully bought a Fiskars with what is supposedly an unbreakable fiberglass handle. I've hit it a time or two but I rarely use it anymore. You know what though? I didn't break it... 3 Share this post Link to post Share on other sites
dcrage 628 #11 Posted April 12, 2022 Oak (especially wood from red oak varieties) are really slow to dry without splitting. In fact the whole log can rot if not split. Rotting takes several years; you do not need to immediately split. 3 Share this post Link to post Share on other sites
ebinmaine 67,463 #12 Posted April 12, 2022 Just now, dcrage said: Oak (especially wood from red oak varieties) are really slow to dry without splitting. In fact the whole log can rot if not split. Rotting takes several years; you do not need to immediately split. I've been told Birch will do the same thing. Especially White birch. It's best to peel the bark and split the log ASAP. 2 Share this post Link to post Share on other sites
Stormin 9,981 #13 Posted April 12, 2022 Split it, Mick. Below is the easy way as my assistant is demonstrating. Then store under cover for a year. Not under a tarp or inside. Allow air to get to it. 2 2 Share this post Link to post Share on other sites
ebinmaine 67,463 #14 Posted April 12, 2022 43 minutes ago, Stormin said: Below is the easy way as my assistant is demonstrating Trina and her mom do about 95% of the splitting for us. I find that to be very easy. 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,041 #15 Posted April 12, 2022 The extent that wood dries is relative to the ambient humidity. Takes 2 years here. Last summer tried something new. Cut down maple trees after the leaves were fully developed. Let them sit until the leaves had dried on the tree - 2 or 3 weeks. Then blocked and split. That wood is as dry now as what was cut 2 years ago and burns the same. The shrinkage checks are very thin if even noticeable. I guess the leaves pulled the free moisture and that started the shrinkage. 4 Share this post Link to post Share on other sites
Mickwhitt 4,621 #16 Posted April 15, 2022 Thanks for all the advice. I decided to see how splitting them now goes, while still pretty fresh. It was really easy, I have a fiskars splitting axe with the fibreglass shaft and it was a breeze. Maybe thati won't be able to move tomorrow but at least the wood is in for next year. 1 4 Share this post Link to post Share on other sites
ebinmaine 67,463 #17 Posted April 15, 2022 On 4/12/2022 at 12:36 PM, ebinmaine said: Fiskars 2 minutes ago, Mickwhitt said: fiskars splitting axe Excellent choice!! Nice work on that stack o' burnables Mick. 1 Share this post Link to post Share on other sites
Mickwhitt 4,621 #18 Posted April 15, 2022 I know its not much compared to the volumes you guys deal with but it is good for us now energy prices have gone mental. 2 2 Share this post Link to post Share on other sites
ebinmaine 67,463 #19 Posted April 15, 2022 2 minutes ago, Mickwhitt said: I know its not much compared to the volumes you guys deal with but it is good for us now energy prices have gone mental. We fell, cut, split, and stack maybe four cord a year. I know it doesn't exactly fall into the category of enjoyable for many people. The BBT and I may be just a tad bit twisted. We really do enjoy the time spent and the physical energy burned in the process. 1 Share this post Link to post Share on other sites
Pullstart 62,848 #20 Posted April 15, 2022 Atta’boy Mick! I love my Fiskars! An old tire helps to keep from picking it up constantly… 2 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #21 Posted April 15, 2022 22 minutes ago, Pullstart said: Atta’boy Mick! I love my Fiskars! An old tire helps to keep from picking it up constantly… What are you doing… making toothpicks ? 3 Share this post Link to post Share on other sites
Mickwhitt 4,621 #22 Posted April 15, 2022 Decent load of cut wood to dry now. we don't have fires every day and really only when its pretty cold and we want to be snug. i also get off cuts of wood from a woodwork buddy so we are pretty cost free on the wood front. just looking into solar panels to see if we can save some electricity. 1 Share this post Link to post Share on other sites
Pullstart 62,848 #23 Posted April 15, 2022 12 minutes ago, Horse Newbie said: What are you doing… making toothpicks ? I was splitting small stuff smaller for a quick, hot fire. You could hear the audible blower (air mattress fan ) pushing into the Maple Syrup Machine we dubbed the ManTucket Syrup Factory. It used to get so hot, you can only imagine what had to get tucked out the way during working hours https://youtu.be/aJgNuteTI2s 2 Share this post Link to post Share on other sites
Pullstart 62,848 #24 Posted March 3, 2023 +1 for the Fiskars again today! Oak rounds. The split is 39” across. The wood is 17-18” tall. I successfully used the wedges a bit at the end, once I actually noticed the wood moving apart and cracked to the bottom. Notice one wedge has a handle for easy retrieval. It’s not safe to swing as a splitter, the handle is terrible loose. 2 1 Share this post Link to post Share on other sites
Pullstart 62,848 #25 Posted March 3, 2023 15 minutes to half, 9 minutes to obliterate. Go Team Fiskars! 2 1 Share this post Link to post Share on other sites
