Ed Kennell 40,509 #1 Posted April 9, 2022 I see a drip under my '96 312Hydro. Need an axle seal number. Mike, @squonk, you got a NAPA number for a 1 1/8" axle? Share this post Link to post Share on other sites
stevasaurus 23,072 #2 Posted April 9, 2022 Hydro seal is SKF 11124 for the Hydro 1 1/8" axle seal. WH #6449 1 1 Share this post Link to post Share on other sites
Ed Kennell 40,509 #3 Posted April 9, 2022 Thanks Steve. Share this post Link to post Share on other sites
squonk 42,579 #4 Posted April 9, 2022 11124 will also be the Napa # Ed 1 1 Share this post Link to post Share on other sites
JoeM 7,937 #5 Posted April 9, 2022 @Ed Kennell The last SKF hydro seals I got were half as thick as the original. The thinner seal allows the seal to be set in deeper and on an area of the axle that might not have a defect. Also It could allow doubling up the seals if necessary. 1 Share this post Link to post Share on other sites
stevasaurus 23,072 #6 Posted April 10, 2022 The deal is Wheel Horse bearing and seal numbers do not cross on anybody's list at an automotive store. Once you have the SKF or Torrington/KOYO number, you can cross that to whatever is out there...National, etc. There is a thinking that double seals are a bad thing. Reason is, the outer seal does not get lubed and can wear in the axle or shaft. 2 2 Share this post Link to post Share on other sites
