entropy
520HC 48" deck questions
entropy
I am going to pull my deck this weekend in order to replace drive belt and either sharpen or replace blades.
I was wondering if anyone had info on the belt part number and/or length of belt as well as the best replacement blades for deck(as well as part number for those as well)
Thanks in advance for the help
Dave
gwest_ca
You should have the deck model number to get the correct blades but the belts will be the same.
entropy
Thank you for the links, I went through the manuals section and I did not see my year model and width. Must have been me man looking as you found them no problem. No new blades needed. The blades are so robust that I just used the angle grinder until I got a good edge. The belt I will still replace and grease gun the spindles
Lee1977
Takes a  Toro # 94-2501  -1/2" v-belt length 103" for the mule drive,  The  48" deck  Toro # 1594 -1/2" v-belt length 107"..
Edited by Lee1977
entropy
Thanks Lee! Just ordered the aramid belt
