briley 5 #1 Posted April 7, 2022 Does anyone know how to remove that front gear after removing the nut? Thanks Share this post Link to post Share on other sites
squonk 41,040 #2 Posted April 7, 2022 You need to remove the other gear first. There is a snap ring that holds that on. After that remove the nut and you might need a small gear puller to get it off the shaft. You must time the shaft 90 degrees opposite of the other shaft so the blades don't hit. 1 Share this post Link to post Share on other sites
ri702bill 8,296 #3 Posted April 8, 2022 (edited) 14 hours ago, squonk said: You must time the shaft 90 degrees opposite of the other shaft so the blades don't hit. ...to avoid a rather noisy territorial dispute.. kind of like the WWI propeller fighter planes that had the forward facing machine gun firing thru the spinning propeller . all is fine until it isn't. Edited April 8, 2022 by ri702bill 1 Share this post Link to post Share on other sites
Handy Don 12,174 #4 Posted April 8, 2022 Two mower deck blades trying to occupy the same space at that same time? Uh oh. Share this post Link to post Share on other sites
