Fishroe
Info on headlight
Fishroe
Only local place I could find now is Napa $15.49
Tractor Supply, Advance Auto don’t have them on their website. Has screw and spade terminals
Edit.  agri has it with the rubber housing
Edited by Fishroe
peter lena
@Fishroe  walmart might have them , got mine on line , with spade terminals , also a good time to , increase grounding , on your unit , if you want to . a simple test upgrade , small alligator clip wire from battery ground bolt to dash area  , to headlight grounding , notice the  difference ?  pete
lynnmor
It might be a good time to replace with PAR 36 LED lamps.
  • Like 3
  • Excellent 4
peter lena
@lynnmor thats what I  got , LED,S,  terrific lighting with almost nothing amp draw.  pete
squonk
Quite often Napa and other stores will have that light with the rubber housing cheaper than the bulb itself. Remove the bulb and throw the housing away.
Fishroe
I know a lot of you like the LEDs but I’m not a big fan of them
I still use them
every lightbulb in my house now is LED
i’ve had to replace three of them in the last two years
I don’t think they last any longer than incandescent bulbs
but the government says I can’t use incandescent anymore
One or two dollars apiece
I guess I’m still living in the 70s and 80s:wacko:
I guess i used the wrong search words on Advance website. I put in 4411 headlights
all I got was headlight bulbs for cars
Lost Pup
I call  it “unicorn” shopping. Many websites today have great products if you will just hidden away.  I usually search and post here to find items, best resource available.
