Searcher60 209 #1 Posted April 6, 2022 Hello, anyone know the belt and blade nuts torque on like a 78360 or 78345 mower deck? Is it the same torque for both nuts? Thanks! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,029 #2 Posted April 6, 2022 I believe the Z spindle assemblies in the ID charts are used in the 78345 and 78360 decks. The torque spec. for the blades is also in the deck operator manuals. 1 1 Share this post Link to post Share on other sites
peter lena 8,579 #3 Posted April 6, 2022 @Searcher60 make sure you use a 6 POINT SOCKET on those nuts , also replace the nuts if corroded or visibly round edge worn. pete Share this post Link to post Share on other sites
Pullstart 62,757 #4 Posted April 6, 2022 Crank it ‘til it snaps, then back it off 1/4 turn. That usually works for me 1 Share this post Link to post Share on other sites
clueless 2,974 #5 Posted April 6, 2022 14 minutes ago, Pullstart said: Crank it ‘til it snaps, then back it off 1/4 turn. That usually works for me Me and you. 1 Share this post Link to post Share on other sites
