Wendell
New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
Ed Kennell
:text-welcomeconfetti: to the :rs:     I'm a hydroman so I don't have an answer, but the gear jammers will be along soon to help.
TJ5208
I think to help prevent shifting while moving because you have to come to a complete stop to shift. Do you have any pictures of the spring?
Edited by TJ Salyers
roadapples
:WRS:
gwest_ca
Welcome to the forum.
Is there a part number on this decal?
SylvanLakeWH
Wendell
I don't know how to post pictures, just graduated from a flip phone. Toro shows part # 99-8028 spring shift control. Item #50 under Hoodstand, console assembly. Over time it has wore a groove in the gear shift lever. Just curious of what the spring shift control was supposed to do.
Achto
:WRS:
I don't have any tractors with spring shift. Tagging along to hear the answer.
gwest_ca
Spring - shift control or shift control spring
They added a switch to the gear transmission shift linkage to make the NMIR (No mow in reverse) system work. The spring likely has something to do with keeping the shifter in the reverse position so it is not confused with 3rd gear shifter position.
I did something similar but simpler many years ago to control a backup lamp - used a reed switch with a magnet mounted on the shifter.
Handy Don
Just pulled up the wiring diagram for the '99 314-8 and that NMIR setup sure does add some complications!
Then went to the IPL. From the little I can discern, it looks like a way to prevent (or strongly discourage?) the shifter from going into Reverse when the PTO is engaged. From the shape of the spring, I can see that it might put wear on the shifter lever--especially if it isn't aligned correctly or if the shifter was being forced into reverse while the PTO was engaged.
Edited by Handy Don
  • Similar Content
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
    • Tap53
      By Tap53
      List of various belt Lengths and Widths text
      Chart belt
      Belts sorted by part number pdf
      4 pages 458KB
      Belts sorted by belt section (cross section) pdf
      4 pages 422KB
    • Goldann520
      By Goldann520
      Well guys, I guess it's so long! Someone bought my JD 212 yesterday,  and couldn't refuse the money for my 520 today.😣 I am no longer a wh owner, so doesnt feel right hangin' out with you guys. Thanks Terry  good luck all. See you down the road.
